Hello, our graylog instance isn’t receiving logs from our application. Below is the configuration:
TCP
bind_address: 0.0.0.0
charset_name: UTF-8
decompress_size_limit: 8388608
max_message_size: 2097152
number_worker_threads: 4
override_source: <empty>
port: 12202
charset_name: UTF-8
port: 12201
recv_buffer_size: 262144
Maximum size:
1.0GiB
Maximum age:
12 hours 0 minutes
Flush policy:
Every 1,000,000 messages or 1 minute 0 seconds
Utilization
0.00%
-264,157,086 unprocessed messages are currently in the journal, in 1 segments.
0 messages have been appended in the last second, 0 messages have been read in the last second.
"cluster_name" : "graylog",
"status" : "green",
"timed_out" : false,
"number_of_nodes" : 1,
"number_of_data_nodes" : 1,
"discovered_master" : true,
"discovered_cluster_manager" : true,
"active_primary_shards" : 15,
"active_shards" : 15,
"relocating_shards" : 0,
"initializing_shards" : 0,
"unassigned_shards" : 0,
"active_shards_percent_as_number" : 100.0
Error with node:
Nodes with too long GC pauses (triggered 7 months ago)
There are Graylog nodes on which the garbage collector runs too long. Garbage collection runs should be as short as possible. Please check whether those nodes are healthy. (Node: cb4163ab-0761-4a85-8c59-f7f3bc8ad814, GC duration: 1057 ms, GC threshold: 1000 ms)
/etc/opensearch/jvm.options
-Xms10g
-Xmx10g
I’m not sure why it’s not processing messages. Our opensearch is healthy and graylog is running. Any ideas on why this happening? I followed the graylog documentation but same error.
