I have an offline graylog (OVA) running. I am using the following config:
Panic Soft
#NoFreeOnExit TRUE
define CERTDIR %ROOT%\cert
define CONFDIR %ROOT%\conf
define LOGDIR %ROOT%\data
define LOGFILE %LOGDIR%\nxlog.log
LogFile %LOGFILE%
Moduledir %ROOT%\modules
CacheDir %ROOT%\data
Pidfile %ROOT%\data\nxlog.pid
SpoolDir %ROOT%\data
# Check the size of our log file hourly, rotate if larger than 5MB
<Schedule>
Every 1 hour
Exec if (file_exists('%LOGFILE%') and \
(file_size('%LOGFILE%') >= 5M)) \
file_cycle('%LOGFILE%', 8);
</Schedule>
# Rotate our log file every week on Sunday at midnight
<Schedule>
When @weekly
Exec if file_exists('%LOGFILE%') file_cycle('%LOGFILE%', 8);
</Schedule>
Module im_msvistalog
# SavePosition True
ReadFromLast True
Query <QueryList>\
<Query Id='1'>\
<Select Path='Application'>*</Select>\
<Select Path='Security'>*</Select>\
<Select Path='System'>*</Select>\
</Query>\
</QueryList>
Module om_udp
Host 192.168.1.189
Port 12204
OutputType GELF
Path in => out
my 1st online setup winserver>graylog works fine however the offline setup windows DC > graylog isnt working. the config file is the same on both networks. Am I missing something? I am seeing the messages in ther 10 in /10 out
