Not able to sort a query result by a given field
Hi !!
I performed an upgrade from GL 2.2 to 2.3 just this week. The upgrade itself was kind of smooth. I upgraded ES from 2.4 to 5.5.
What is not working right now is if I try to sort a query result in GL, given a specific field, in this case, server_response_time, I got the following error on GL GUI:
Could not execute search
There was an error executing your search. Please check your Graylog server logs for more information.
Error Message:
Unable to perform search query.
Details:
Search status code:
500
Search response:
cannot GET http://10.10.0.123:12900/api/search/universal/absolute?query=server_response_time%3A>45000&from=2017-08-16T14%3A13%3A54.000Z&to=2017-08-16T14%3A31%3A57.000Z&limit=150&sort=server_response_time%3Adesc (500)
And this is the error in ES:
ES LOG
org.elasticsearch.transport.RemoteTransportException: [3AhCLKK][10.10.0.121:9300][indices:data/read/search[phase/query]]
Caused by: org.elasticsearch.index.query.QueryShardException: No mapping found for [server_response_time] in order to sort on
at org.elasticsearch.search.sort.FieldSortBuilder.build(FieldSortBuilder.java:262) ~[elasticsearch-5.5.1.jar:5.5.1]
at org.elasticsearch.search.sort.SortBuilder.buildSort(SortBuilder.java:156) ~[elasticsearch-5.5.1.jar:5.5.1]
at org.elasticsearch.search.SearchService.parseSource(SearchService.java:630) ~[elasticsearch-5.5.1.jar:5.5.1]
at org.elasticsearch.search.SearchService.createContext(SearchService.java:481) ~[elasticsearch-5.5.1.jar:5.5.1]
at org.elasticsearch.search.SearchService.createAndPutContext(SearchService.java:457) ~[elasticsearch-5.5.1.jar:5.5.1]
at org.elasticsearch.search.SearchService.executeQueryPhase(SearchService.java:253) ~[elasticsearch-5.5.1.jar:5.5.1]
at org.elasticsearch.action.search.SearchTransportService$6.messageReceived(SearchTransportService.java:330) ~[elasticsearch-5.5.1.jar:5.5.1]
at org.elasticsearch.action.search.SearchTransportService$6.messageReceived(SearchTransportService.java:327) ~[elasticsearch-5.5.1.jar:5.5.1]
at org.elasticsearch.transport.RequestHandlerRegistry.processMessageReceived(RequestHandlerRegistry.java:69) ~[elasticsearch-5.5.1.jar:5.5.1]
at org.elasticsearch.transport.TcpTransport$RequestHandler.doRun(TcpTransport.java:1544) ~[elasticsearch-5.5.1.jar:5.5.1]
at org.elasticsearch.common.util.concurrent.ThreadContext$ContextPreservingAbstractRunnable.doRun(ThreadContext.java:638) ~[elasticsearch-5.5.1.jar:5.5.1]
at org.elasticsearch.common.util.concurrent.AbstractRunnable.run(AbstractRunnable.java:37) ~[elasticsearch-5.5.1.jar:5.5.1]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) ~[?:1.8.0_121]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) ~[?:1.8.0_121]
at java.lang.Thread.run(Thread.java:745) [?:1.8.0_121]
What could be happening ??
How can I fix the mapping ?
This is the query being executed at ES:
[SearchRequest{searchType=QUERY_THEN_FETCH, indices=[surplus_260, surplus_263, surplus_264, surplus_261, surplus_262, surplus_223, surplus_267, surplus_224, surplus_268, surplus_265, surplus_266, surplus_258, surplus_259, publicpurchase__359, doclibrary__351, surplus_270, surplus_271, surplus_230, surplus_274, surplus_231, surplus_275, surplus_272, surplus_273, surplus_234, surplus_278, surplus_235, surplus_279, surplus_312, graylog_116, surplus_232, surplus_276, surplus_233, surplus_277, surplus_310, surplus_227, surplus_228, surplus_225, surplus_269, surplus_226, surplus_229, fail2ban__360, surplus_281, surplus_282, surplus_280, surplus_241, surplus_242, surplus_240, surplus_245, surplus_246, surplus_243, surplus_244, surplus_238, surplus_239, surplus_236, surplus_237, fail2ban__353, publicsurplus__375, surplus_252, surplus_253, surplus_250, surplus_251, surplus_256, surplus_257, surplus_254, surplus_255, surplus_249, surplus_247, surplus_248], indicesOptions=IndicesOptions[id=38, ignore_unavailable=false, allow_no_indices=true, expand_wildcards_open=true, expand_wildcards_closed=false, allow_alisases_to_multiple_indices=true, forbid_closed_indices=true], types=[message], routing=‘null’, preference=‘null’, requestCache=null, scroll=null, source={
“from” : 0,
“size” : 150,
“query” : {
“bool” : {
“must” : [
“match_all” : {
“boost” : 1.0
“filter” : [
“bool” : {
“must” : [
“range” : {
“timestamp” : {
“from” : “2017-08-16 16:10:59.173”,
“to” : “2017-08-16 16:25:59.173”,
“include_lower” : true,
“include_upper” : true,
“boost” : 1.0
“disable_coord” : false,
“adjust_pure_negative” : true,
“boost” : 1.0
“boost” : 1.0
“sort” : [
“server_response_time” : {
“order” : “asc”
}}] lastShard [true]
