Not able to get the Web GUI console for graylog
hi ,
Graylog web console is taking to much time to load and after that getting the below Error, Please advice
Server currently unavailable
We are experiencing problems connecting to the Graylog server running on http://10.200.100.49:9000/api/. Please verify that the server is healthy and working correctly.
You will be automatically redirected to the previous page once we can connect to the server.
Do you need a hand? We can help you.
Error in the logs
2017-09-19T17:44:42.105Z INFO [ServerBootstrap] Graylog server up and running.
2017-09-19T17:49:32.271Z ERROR [UsageStatsClusterPeriodical] Error while uploading anonymous usage statistics
2017-09-19T17:49:32.571Z ERROR [UsageStatsNodePeriodical] Error while uploading anonymous usage statistics
Is http://10.200.100.49:9000/api/ the correct URI for the Graylog REST API which is accessible to your web browser?
What’s the configuration of your Graylog node?
Please also read http://docs.graylog.org/en/2.3/pages/configuration/web_interface.html
