node-gelf-pro
@kkamkou
View on Github
Open Issues
Stargazers
node-gelf - Graylog2 client library for Node.js. Pro - because of code-quality (at 2015). GELF - The Graylog Extended Log Format.
Installation
"dependencies": {
"gelf-pro": "~1.3" // see the "releases" section
npm install gelf-pro ( ALL node.js versions are supported [0.x to 18.x] ![]()
