New AD/LDAP users not synched with Graylog
Users belonging to newer OU’s are not able to login via LDAP credentials.
If I try to add/whitelist new OU’s in Search base DN, it leads to LDAP errors DSID-0310022D, DSID -03100225
Also many users of the currently added OU are not synchronized, i.e the OU has more than the number of users that are being discovered on Graylog
  • OS Information: Private Build 1.8.0_282 on Linux 5.4.0-1041-aws
  • Package Version: Graylog 4.0.5+d95b909
Search base DN : OU=ABC,OU=XYZ,DC=ABCCORP,DC=com (values for representation purposes)
Search pattern: (&(mail=*)(sAMAccountName={0}))
name Attribute: cn
Full Name Attribute: displayName
ID Attribute: sn
Tried to add OU’s in the Authentication → User Synchronization and Test user Login (fails, if new OU is added)
If OU settings are changed Graylog login stops working, and Admin login, reverting authentication settings to previous values fixes it.
Please suggest the configuration, LDAP settings which would help with the AD Sync.
Refer: AD/LDAP Authentication with groups, users not found - #7 by shoothub
Hello && Welcome
Perhaps try some simple like this under User Synchronization.
Search Base DN:   CN=Users,DC=domain,DC=net
Search Pattern: (&(objectClass=user)(sAMAccountName={0}))
Name Attribute: sAMAccountName
Lets say is your users are in a OU called mail then something like this.
Search Base DN:   CN=mail,DC=domain,DC=net
This would depend on how you setup your AD and your other configurations that are not shown in this post.
I would advice checking permissions for the user your using in System User DN also.
This would require at lest a read role in Active directory for that user.
Perhaps check out this post. It might give you some clues
When posting please take a look here this may help out.
Thanks for your reply.
While adding multiple OU’s did not work, and the suggested configuration worked, but still new users were not discovered.
At the moment, I have broadened the OU search base DN (to the entire Organization), thereby all the OU’s under the top level root, are now accessible.
This is not a best case solution as huge Active directories might cause slower lookups/authentication as the search base filter is fully open.
Thanks & Regards,
Omkar Kadam
Hello
Working with someone’s AD is kind of touchy, meaning there is sensitive data. What I found was how you structure your Active Directory then configure your Attribute mapping for user accounts and
Attribute mapping for groups. This would be applied to your Search Base DN.
To find the correct configurations needed I would do the following.
Open a Windows command prompt.
Type the command:
dsquery user -name <known username>
Example: If you are searching for all users named "John", you can enter the username as John* to get a list of all users who's name is John.
The result will look like:
"CN=John.Smith,CN=Users,DC=MyDomain,DC=com"
- In Symantec Reporter's LDAP/Directory settings, when asked for a User Base DN, enter:
Now for Groups I would execute this.
Finding the Group Base DN
Type the command:
dsquery group -name <known group name>.
Example: If you are searching for a group called Users, you can enter the group name as Users* to get a list of all groups who's name contains "Users"
"CN=Users,CN=Builtin,DC=MyDomain,DC=com"
I don’t think this is a Graylog issue, I believe you need the correct configurations and/or permission
on the Attribute mapping for groups in the active directory.
Hope that helps
You can narrow your user and group search patterns - Is the user a member of Graylog_Kahunas
User search pattern:
(&(objectClass=user)(sAMAccountName={0})(objectCategory=person)(memberOf=CN=graylog_kahunas,OU=admin_groups,OU=permissions,OU=process,DC=comapny,DC=tld))
Group search pattern:
(&(objectClass=group)(cn=graylog_kahunas))
