Nested Field Using GrayLog
Hi All,
I have a data that I like to ingest into the Graylog using fluent-bit. The following the Data:
{“timestamp”:“2023-10-01T20:36:53.079+0000”,“rule”:{“level”:3,“description”:“Windows User Logoff.”,“id”:“60137”,“firedtimes”:275,“mail”:false,“groups”:[“windows”,“windows_security”],“gdpr”:[“IV_32.2”],“hipaa”:[“164.312.b”],“nist_800_53”:[“AC.7”,“AU.14”],“pci_dss”:[“10.2.5”],“tsc”:[“CC6.8”,“CC7.2”,“CC7.3”]},“agent”:{“id”:“045”,“name”:“HOSTNAME”,“ip”:“10.6.57.51”},“manager”:{“name”:“OSHW01”},“id”:“1696192613.464067641”,“decoder”:{“name”:“windows_eventchannel”},“data”:{“win”:{“system”:{“providerName”:“Microsoft-Windows-Security-Auditing”,“providerGuid”:“{54849625-5478-4994-a5ba-3e3b0328c30d}”,“eventID”:“4634”,“version”:“0”,“level”:“0”,“task”:“12545”,“opcode”:“0”,“keywords”:“0x8020000000000000”,“systemTime”:“2023-10-01T20:36:52.075049500Z”,“eventRecordID”:“47135776”,“processID”:“664”,“threadID”:“2824”,“channel”:“Security”,“computer”:“8",“severityValue”:“AUDIT_SUCCESS”,“message”:""An account was logged off.\r\n\r\nSubject:\r\n\tSecurity ID:\t\tS-1-5-21-281294383-1138842768-2788462225-1134\r\n\tAccount Name:\t\tgensvcadmin\r\n\tAccount Domain:\t\t\r\n\tLogon ID:\t\t0xBCC4EDEE\r\n\r\nLogon Type:\t\t\t3\r\n\r\nThis event is generated when a logon session is destroyed. It may be positively correlated with a logon event using the Logon ID value. Logon IDs are only unique between reboots on the same computer."“},“eventdata”:{“targetUserSid”:“S-1-5-21-281294383-1138842768-2788462225-1134”,“targetUserName”:“gensvcadmin”,“targetDomainName”:”**”,“targetLogonId”:“0xbcc4edee”,“logonType”:“3”}}},“location”:“EventChannel”}
The Data is ok when I use the Extractor
The data is not represented correctly as the field that is agent.id is represented as agent_id. I need the index to be nested.
Any Suggestion can help?
You can’t use dots in graylog field names they will be automatically converted to underscores. Your best bet would be to use a pipeline and use the flatten json function, it will take the nested names and concatenate them, and then you can work with field renaming if you need to.
Is there an example that I can use?
