I am running multiple graylog servers in one AWS account using AWS Elasticsearch. AWS Elasticsearch clusters must have unique names.
The server.conf directive 'elasticsearch_cluster_name" was removed in 2.3. How do I specify the cluster name in the lastest Graylog version?
That’s not required since Graylog 2.3.0.
Thank you for responding, it is required for me because the cluster name is not ‘graylog’ so I need to specify a different name.
no need from a Graylog perspective of that. You define the http endpoint where Graylog connects to and it doesn’t matter what name the Elasticsearch Cluster has.
http
So it is up to you to choose one name you like for the ES Cluster.
