Need help in search query
Hi team,
My message being parsed as follows
rest_message
1 method=GET url=http://192.168.44.44/Invoice.doc sent=/var/lib/inetsim/http/fakefiles/sample.doc postdata
I need to set up a query where if rest_message field contains “url=” but dang I am unable to match those out. Can someone please help?
Ah …got the answer
Also note that message , full_message , and source are the only fields that are being analyzed by default. While wildcard searches (using * and ? ) work on all indexed fields, analyzed fields will behave a little bit different. See wildcard and regexp queries for details.
Care to share that answer with the rest? :wink: Somebody else could learn from it :slight_smile:
That is been shared!! see my response
You need to enable wildcard searches in server.conf file.
