Need help getting IIS logs into Graylog 2.3
From a Windows 10 pro machine running Graylog 2.3.1 in virtual box I want to send IIS logs into Graylog.
I can’t find an example of the Path to Logfile for the Filebeat input and I think that is what is wrong. Here is what I got:
[‘C:\inetpub\logs\LogFiles**’]
The IIS logs I want are on the same Windows 10 pro.
•Graylog Version: 2.3.1-3 (in virtual box)
•Elasticsearch Version:
•MongoDB Version:
•Operating System: Windows 10 pro
•Browser version: Internet Explorer 11
What is the path to the log files of IIS on your machine?
C:\inetpub\logs\LogFiles\*\*
sorry I typed it wrong in my post but, in my Graylog beats input I typed it like this
['C:\inetpub\logs\LogFiles\*\*']
Please post the complete configuration of Filebeat.
According to https://www.elastic.co/guide/en/beats/filebeat/5.6/configuration-filebeat-options.html#prospector-paths, using these globs should work.
filebeat:
  prospectors:
  - encoding: plain
    fields:
      collector_node_id: graylog-collector-sidecar
      gl2_source_collector: 215c8afc-8842-4394-9781-d09355560338
      type: log
    ignore_older: 0
    paths:
    - C:\inetpub\logs\LogFiles\*\*
    scan_frequency: 10s
    tail_files: true
    type: log
output:
  logstash:
    hosts:
    - localhost:5045
path:
  data: C:\Program Files\graylog\collector-sidecar\cache\filebeat\data
  logs: C:\Program Files\graylog\collector-sidecar\logs
tags:
- Windows
- iis
Which version of Filebeat are you using?
What’s the output of the following command in the Command Prompt? (https://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/tree.mspx)
tree C:\inetpub\logs\LogFiles /f
Filebeat was in the Collector_sidecar_installer_0.1.4-1 package. I don’t know which version it is.
The result of tree is this and there about 25 lines in the log file.
Structure du dossier pour le volume Programmes
Le numéro de série du volume est BED0-4466
C:\INETPUB\LOGS\LOGFILES
└───W3SVC1
u_ex171012.log
Have lines been added to the log file while Filebeat was running?
What’s in the log output of Filebeat itself?
Here it is.
2017-10-13T11:12:47-04:00 INFO Home path: [C:\Program Files\graylog\collector-sidecar] Config path: [C:\Program Files\graylog\collector-sidecar] Data path: [C:\Program Files\graylog\collector-sidecar\cache\filebeat\data] Logs path: [C:\Program Files\graylog\collector-sidecar\logs]
2017-10-13T11:12:47-04:00 INFO Setup Beat: filebeat; Version: 5.5.1
2017-10-13T11:12:47-04:00 INFO Max Retries set to: 3
2017-10-13T11:12:47-04:00 INFO Activated logstash as output plugin.
2017-10-13T11:12:47-04:00 INFO Publisher name: QD303167
2017-10-13T11:12:47-04:00 INFO Flush Interval set to: 1s
2017-10-13T11:12:47-04:00 INFO Max Bulk Size set to: 2048
2017-10-13T11:12:47-04:00 ERR Not loading modules. Module directory not found: C:\Program Files\graylog\collector-sidecar\module
2017-10-13T11:12:47-04:00 INFO filebeat start running.
2017-10-13T11:12:47-04:00 INFO Registry file set to: C:\Program Files\graylog\collector-sidecar\cache\filebeat\data\registry
2017-10-13T11:12:47-04:00 ERR Error: The service process could not connect to the service controller.
2017-10-13T11:12:47-04:00 INFO Loading registrar data from C:\Program Files\graylog\collector-sidecar\cache\filebeat\data\registry
2017-10-13T11:12:47-04:00 INFO States Loaded from registrar: 1
2017-10-13T11:12:47-04:00 INFO Loading Prospectors: 2
2017-10-13T11:12:47-04:00 INFO Starting Registrar
2017-10-13T11:12:47-04:00 INFO Start sending events to output
2017-10-13T11:12:47-04:00 INFO Starting spooler: spool_size: 2048; idle_timeout: 5s
2017-10-13T11:12:47-04:00 INFO Prospector with previous states loaded: 1
2017-10-13T11:12:47-04:00 INFO Starting prospector of type: log; id: 5460310343517729515
2017-10-13T11:12:47-04:00 INFO Prospector with previous states loaded: 0
2017-10-13T11:12:47-04:00 INFO Starting prospector of type: log; id: 13856082215811419279
2017-10-13T11:12:47-04:00 INFO Loading and starting Prospectors completed. Enabled prospectors: 2
2017-10-13T11:13:17-04:00 INFO Non-zero metrics in the last 30s: publish.events=1 registrar.states.current=1 registrar.states.update=1 registrar.writes=1
2017-10-13T11:13:47-04:00 INFO No non-zero metrics in the last 30s
UPDATE: In the meantime, I ran the “filebeat -c filebeat.yml -configtest” command and my config is ok
In fact I tried with generic application logs (not IIS) as well with Filebeat and it doesn’t work either. How should I write the Path to log if the logs file are for example in c:\logs?
In the example I see /var/logs/*.log but I don’t even understand where this would point on my Windows machine.
Winlogbeat works fine but the configuration is different.
UPDATE: Looking back at the config, I see output to logstash. Is this ok with Graylog? I have no logstash in this setup. However, it is when I modify the Collector configuration that those settings are set. I did not modify it manually.
output:
logstash:
hosts:
- localhost:5045
I tried playing around with the path using globs or based on examples in the filebeat.full example on elastic site.
I even tried updating the Executable file of filebeat to the latest.
I know it should work but the conclusions of our tests is that Filebeat doesn’t work in our POC Sadly. I reviewed all configurations and looked at the logs but can’t find why, This seems not specific to IIS Logs (as IIS Logs are juste log files anyway)
At least there are no problem with Winlogbeat.
Are you sure that the system user running Filebeat has permission to read the directory you’ve configured?
You can also activate debug mode for Filebeat to see what it’s doing in detail.
https://www.elastic.co/guide/en/beats/filebeat/current/enable-filebeat-debugging.html
Good point, but it’s the SYSTEM account that runs filbeat. It has access on all subfolders and files in c:\inetpub\ including logs.
As for running in debug, I saw that but as I’m not explicitly starting Filbeat as it is the Collector_Sidecar that fires Filebeat, I’m not shure where I would add the flags -e -d “publish” in this case.
I also tried setting the logging.level: debug in the filebeat.yml but each time the Collector Sidecar is restarted the filebeat.yml config is reset and this line disappears.
You can stop the Sidecar service with graylog-collector-sidecar.exe -service stop or in the system configuration under services. Then you can start filebeat manually with debug options and the last generated configuration. Please post the output so that we can take a look.
Thanks for the idea, I tried that and found that since I want to test with old logs, that may be the problem. But, then I changed the older_ignore to 5000000 and even I I see “new state added” in the logs", I see nothing in my Graylog input. Here are two parts of the output which I found different :
2017/10/18 17:22:18.532045 state.go:64: DBG  New state added for C:\ELKlogs\elasticsrv-stdout.2017-06-12.log
2017/10/18 17:22:18.532045 state.go:64: DBG  New state added for C:\ELKlogs\elasticsrv-stdout.2017-07-31.log
2017/10/18 17:22:18.532045 state.go:64: DBG  New state added for C:\ELKlogs\elasticsearch-2017-07-31.log
2017/10/18 17:22:18.532045 state.go:64: DBG  New state added for C:\ELKlogs\elasticsearch_index_indexing_slowlog.log
2017/10/18 17:22:18.532045 state.go:64: DBG  New state added for C:\ELKlogs\elasticsrv-stderr.2017-06-05.log
2017/10/18 17:22:18.532045 state.go:64: DBG  New state added for C:\ELKlogs\elasticsrv-stderr.2017-06-14.log
2017/10/18 17:22:18.532045 state.go:64: DBG  New state added for C:\ELKlogs\elasticsrv-stderr.2017-09-18.log
2017/10/18 17:22:18.532045 state.go:64: DBG  New state added for C:\ELKlogs\elasticsrv.2017-06-12.log
2017/10/18 17:22:18.532045 state.go:64: DBG  New state added for C:\ELKlogs\elasticsearch-2017-06-05.log
2017/10/18 17:22:18.532045 state.go:64: DBG  New state added for C:\ELKlogs\elasticsearch-2017-06-06.log
2017/10/18 17:22:18.532045 state.go:64: DBG  New state added for C:\ELKlogs\elasticsearch-2017-06-14.log
2017/10/18 17:22:18.532045 state.go:64: DBG  New state added for C:\ELKlogs\elasticsearch-2017-09-18.log
2017/10/18 17:22:18.532045 state.go:64: DBG  New state added for C:\ELKlogs\elasticsearch_access.log
2017/10/18 17:22:18.532045 state.go:64: DBG  New state added for C:\ELKlogs\elasticsrv-stderr.2017-06-12.log
2017/10/18 17:22:18.532045 state.go:64: DBG  New state added for C:\ELKlogs\elasticsrv-stdout.2017-06-07.log
2017/10/18 17:22:18.532045 state.go:64: DBG  New state added for C:\ELKlogs\elasticsrv.2017-09-18.log
2017/10/18 17:22:18.532045 state.go:64: DBG  New state added for C:\ELKlogs\elasticsrv.2017-09-29.log
2017/10/18 17:22:18.532045 state.go:64: DBG  New state added for C:\ELKlogs\elasticsrv.2017-10-12.log
2017/10/18 17:22:18.532045 state.go:64: DBG  New state added for C:\ELKlogs\elasticsearch-2017-06-08.log
2017/10/18 17:22:18.532045 state.go:64: DBG  New state added for C:\ELKlogs\elasticsearch_index_search_slowlog.log
2017/10/18 17:22:18.532045 state.go:64: DBG  New state added for C:\ELKlogs\elasticsrv-stderr.2017-06-07.log
2017/10/18 17:22:18.532045 state.go:64: DBG  New state added for C:\ELKlogs\elasticsrv-stderr.2017-06-13.log
2017/10/18 17:22:18.532045 state.go:64: DBG  New state added for C:\ELKlogs\elasticsrv-stderr.2017-09-28.log
Here is another part
2017/10/18 18:07:30.915916 prospector_log.go:313: DBG  File didn't change: C:\ELKlogs\elasticsrv-stderr.2017-10-11.log
2017/10/18 18:07:30.915916 prospector_log.go:226: DBG  Check file for harvesting: C:\ELKlogs\elasticsrv.2017-06-07.log
2017/10/18 18:07:30.915916 prospector_log.go:320: DBG  Ignore file because ignore_older reached: C:\ELKlogs\elasticsrv.2017-06-07.log
2017/10/18 18:07:30.915916 prospector_log.go:226: DBG  Check file for harvesting: C:\ELKlogs\elasticsrv.2017-10-12.log
2017/10/18 18:07:30.915916 prospector_log.go:259: DBG  Update existing file for harvesting: C:\ELKlogs\elasticsrv.2017-10-12.log, offset: 1377
2017/10/18 18:07:30.915916 prospector_log.go:313: DBG  File didn't change: C:\ELKlogs\elasticsrv.2017-10-12.log
2017/10/18 18:07:30.915916 prospector_log.go:226: DBG  Check file for harvesting: C:\ELKlogs\elasticsrv-stderr.2017-06-06.log
2017/10/18 18:07:30.915916 prospector_log.go:320: DBG  Ignore file because ignore_older reached: C:\ELKlogs\elasticsrv-stderr.2017-06-06.log
2017/10/18 18:07:30.916417 prospector_log.go:226: DBG  Check file for harvesting: C:\ELKlogs\elasticsrv-stderr.2017-06-08.log
2017/10/18 18:07:30.916417 prospector_log.go:320: DBG  Ignore file because ignore_older reached: C:\ELKlogs\elasticsrv-stderr.2017-06-08.log
2017/10/18 18:07:30.916417 prospector_log.go:226: DBG  Check file for harvesting: C:\ELKlogs\elasticsearch_index_indexing_slowlog.log
2017/10/18 18:07:30.916417 prospector_log.go:226: DBG  Check file for harvesting: C:\ELKlogs\elasticsrv-stderr.2017-06-13.log
2017/10/18 18:07:30.916417 prospector_log.go:320: DBG  Ignore file because ignore_older reached: C:\ELKlogs\elasticsrv-stderr.2017-06-13.log
2017/10/18 18:07:30.916417 prospector_log.go:226: DBG  Check file for harvesting: C:\ELKlogs\elasticsearch_deprecation.log
2017/10/18 18:07:30.916916 prospector_log.go:259: DBG  Update existing file for harvesting: C:\ELKlogs\elasticsearch_deprecation.log, offset: 21149
2017/10/18 18:07:30.916916 prospector_log.go:313: DBG  File didn't change: C:\ELKlogs\elasticsearch_deprecation.log
2017/10/18 18:07:30.916916 prospector_log.go:226: DBG  Check file for harvesting: C:\ELKlogs\elasticsrv.2017-09-29.log
2017/10/18 18:07:30.916916 prospector_log.go:259: DBG  Update existing file for harvesting: C:\ELKlogs\elasticsrv.2017-09-29.log, offset: 617
2017/10/18 18:07:30.916916 prospector_log.go:313: DBG  File didn't change: C:\ELKlogs\elasticsrv.2017-09-29.log
2017/10/18 18:07:30.916916 prospector_log.go:226: DBG  Check file for harvesting: C:\ELKlogs\elasticsrv-stdout.2017-10-11.log
2017/10/18 18:07:30.916916 prospector_log.go:259: DBG  Update existing file for harvesting: C:\ELKlogs\elasticsrv-stdout.2017-10-11.log, offset:
118376
2017/10/18 18:07:30.916916 prospector_log.go:313: DBG  File didn't change: C:\ELKlogs\elasticsrv-stdout.2017-10-11.log
2017/10/18 18:07:30.916916 prospector_log.go:226: DBG  Check file for harvesting: C:\ELKlogs\elasticsrv-stdout.2017-06-05.log
2017/10/18 18:07:30.916916 prospector_log.go:320: DBG  Ignore file because ignore_older reached: C:\ELKlogs\elasticsrv-stdout.2017-06-05.log
2017/10/18 18:07:30.916916 prospector_log.go:226: DBG  Check file for harvesting: C:\ELKlogs\elasticsrv-stdout.2017-09-18.log
2017/10/18 18:07:30.916916 prospector_log.go:259: DBG  Update existing file for harvesting: C:\ELKlogs\elasticsrv-stdout.2017-09-18.log, offset:
4321
2017/10/18 18:07:30.916916 prospector_log.go:313: DBG  File didn't change: C:\ELKlogs\elasticsrv-stdout.2017-09-18.log
2017/10/18 18:07:30.916916 prospector_log.go:226: DBG  Check file for harvesting: C:\ELKlogs\elasticsrv.2017-06-06.log
2017/10/18 18:07:30.916916 prospector_log.go:320: DBG  Ignore file because ignore_older reached: C:\ELKlogs\elasticsrv.2017-06-06.log
2017/10/18 18:07:30.916916 prospector_log.go:226: DBG  Check file for harvesting: C:\ELKlogs\elasticsrv.2017-06-13.log
2017/10/18 18:07:30.917418 prospector_log.go:320: DBG  Ignore file because ignore_older reached: C:\ELKlogs\elasticsrv.2017-06-13.log
2017/10/18 18:07:30.917418 prospector_log.go:226: DBG  Check file for harvesting: C:\ELKlogs\elasticsrv-stderr.2017-09-29.log
2017/10/18 18:07:30.917418 prospector_log.go:259: DBG  Update existing file for harvesting: C:\ELKlogs\elasticsrv-stderr.2017-09-29.log, offset: 65
2017/10/18 18:07:30.917418 prospector_log.go:313: DBG  File didn't change: C:\ELKlogs\elasticsrv-stderr.2017-09-29.log
2017/10/18 18:07:30.917418 prospector_log.go:226: DBG  Check file for harvesting: C:\ELKlogs\elasticsrv-stdout.2017-07-31.log
2017/10/18 18:07:30.917418 prospector_log.go:320: DBG  Ignore file because ignore_older reached: C:\ELKlogs\elasticsrv-stdout.2017-07-31.log
2017/10/18 18:07:30.917418 prospector_log.go:226: DBG  Check file for harvesting: C:\ELKlogs\elasticsrv-stdout.2017-09-28.log
2017/10/18 18:07:30.917418 prospector_log.go:259: DBG  Update existing file for harvesting: C:\ELKlogs\elasticsrv-stdout.2017-09-28.log, offset:
1708262
2017/10/18 18:07:30.917418 prospector_log.go:313: DBG  File didn't change: C:\ELKlogs\elasticsrv-stdout.2017-09-28.log
2017/10/18 18:07:30.917418 prospector_log.go:226: DBG  Check file for harvesting: C:\ELKlogs\elasticsrv.2017-09-28.log
2017/10/18 18:07:30.917418 prospector_log.go:259: DBG  Update existing file for harvesting: C:\ELKlogs\elasticsrv.2017-09-28.log, offset: 5747
2017/10/18 18:07:30.917418 prospector_log.go:313: DBG  File didn't change: C:\ELKlogs\elasticsrv.2017-09-28.log
2017/10/18 18:07:30.917919 prospector_log.go:226: DBG  Check file for harvesting: C:\ELKlogs\elasticsearch-2017-06-05.log
2017/10/18 18:07:30.917919 prospector_log.go:320: DBG  Ignore file because ignore_older reached: C:\ELKlogs\elasticsearch-2017-06-05.log
2017/10/18 18:07:30.917919 prospector_log.go:226: DBG  Check file for harvesting: C:\ELKlogs\elasticsearch.log
2017/10/18 18:07:30.917919 prospector_log.go:259: DBG  Update existing file for harvesting: C:\ELKlogs\elasticsearch.log, offset: 1700501
2017/10/18 18:07:30.917919 prospector_log.go:313: DBG  File didn't change: C:\ELKlogs\elasticsearch.log
2017/10/18 18:07:30.917919 prospector_log.go:91: DBG  Prospector states cleaned up. Before: 56, After: 56
2017/10/18 18:07:32.577484 spooler.go:89: DBG  Flushing spooler because of timeout. Events flushed: 0
2017/10/18 18:07:37.579416 spooler.go:89: DBG  Flushing spooler because of timeout. Events flushed: 0
2017/10/18 18:07:37.587265 prospector.go:183: DBG  Run prospector
2017/10/18 18:07:37.587265 prospector_log.go:70: DBG  Start next scan
2017/10/18 18:07:37.588246 prospector_log.go:226: DBG  Check file for harvesting: C:\inetpub\logs\LogFiles\W3SVC1\u_ex171012.log
2017/10/18 18:07:37.589227 prospector_log.go:259: DBG  Update existing file for harvesting: C:\inetpub\logs\LogFiles\W3SVC1\u_ex171012.log,
offset: 3568
2017/10/18 18:07:37.589227 prospector_log.go:313: DBG  File didn't change: C:\inetpub\logs\LogFiles\W3SVC1\u_ex171012.log
2017/10/18 18:07:37.589227 prospector_log.go:226: DBG  Check file for harvesting: C:\inetpub\logs\LogFiles\W3SVC1\u_ex171016.log
2017/10/18 18:07:37.589227 prospector_log.go:259: DBG  Update existing file for harvesting: C:\inetpub\logs\LogFiles\W3SVC1\u_ex171016.log,
offset: 1296
2017/10/18 18:07:37.589227 prospector_log.go:313: DBG  File didn't change: C:\inetpub\logs\LogFiles\W3SVC1\u_ex171016.log
2017/10/18 18:07:37.589227 prospector_log.go:91: DBG  Prospector states cleaned up. Before: 2, After: 2
Nothing in the logs that explains your problem. Could check the log for messages like: INFO Connecting error publishing events (retrying): dial tcp xxxx:5045: getsockopt: connection refused
Maybe it’s a simple networking problem, that your virtual machine is not reachable from the outside?
I had no issues getting IIS logs to graylog using NXLOG. If that is an option I could work with you to get it setup and send you a working config. Bonus NXLOG works fine with collector and can reformat as well as ship to a gelf input for you. Not needing extractors on the graylog side is super nice. Let me know.
I would be interested Matt. I am not importing IIS logs right now, but I would be interested in seeing what you have used for a conf file.
would you like the config here or in PM?
Just post it here so that other users having the same question don’t have to bother you each individually. :wink:
