Modify Shard number
I have 3 servers for my cluster Graylog2 on Graylog 2.2.3.
I modify the shard number on “Default index set” 4 to 3 because I have my server number 2 that have 2 folder.
How to delete one folder on this server for to have juste one folder by server ?
Regards
Hej @Groucou
maybe you can describe a little more in detail:
  • what did you have installed
  • what did you change
  • what was the reason for that change
  • what is the exact question
what did you have installed :
  • 3 Servers Ubuntu 16.04 with cluster Graylog and elasticsearch
what did you change :
  • Number shard elasticsearch 4 to 3
what was the reason for that change :
  • Because i would like to have that all my server have the same size of folder /elasticsearch/graylog-elasticsearch/nodes/0/indices
Please elaborate on that. I don’t understand what you mean.
I’m sorry,
I juste modify the index shard number since 4 to 3.
But for the moment there are always 4 shard :
How to have only 3 shard ? Beacuse I have 3 server.
hej @Groucou
every new index will only have 3 shards - that setting does not change any of the current available. That is only for new. So you might want to rotate the index to create a new with only the wanted amount of shards.
