Missing log_level from source.
Hello, I’m currently using Graylog Data Node 6.1, and I’ve set everything up following the official GrayloProcessing: image.png…
g instructions. I can successfully pull logs using the Sidecar; however, I’ve noticed that the field is missing from the log data. I consulted some colleagues, and they mentioned that the field should be included by default, unless it was overlooked during the setup. Could you help me identify the cause of this issue and suggest how to fix it?
