Messages getting updated in graylog_deflector
Hi Team
My messages are getting updated in graylog_deflector. I have created another index called graylog_0, but that is not getting updated. Please help.
Srumith.
graylog_deflector should be an index alias, not a real index.
If it is an index instead of an index alias (also check the logs of your Graylog nodes for that), perform the following steps to rectify the situation:
  1. Stop all Graylog nodes
  2. (OPTIONAL) If you want to keep the already ingested messages, reindex them into the graylog_0 index via the Elasticsearch Reindex API:
    https://www.elastic.co/guide/en/elasticsearch/reference/5.6/docs-reindex.html
  3. Delete the graylog_deflector index:
    https://www.elastic.co/guide/en/elasticsearch/reference/5.6/indices-delete-index.html
  4. Add action.auto_create_index: false to all Elasticsearch configuration files in your cluster and restart all Elasticsearch nodes:
    https://www.elastic.co/guide/en/elasticsearch/reference/5.6/docs-index_.html#index-creation
    https://www.elastic.co/guide/en/elasticsearch/guide/2.x/_creating_an_index.html
  5. Start the master Graylog node
