Message size per stream
Hi folks,
I am wondering if is there a way to see/get the message size ,for instance, per stream to calculate the Storage requirement for a bigger environment than my test-lab. And also to get the storage requriement per sending instance (linux,Windows,NetworkDevice).
Thx!
There is special field gl2_accounted_message_size from graylog 3.2 you can use to aggregate message size.
https://docs.graylog.org/en/3.2/pages/upgrade/graylog-3.2.html?#accounted-message-size-field
https://docs.graylog.org/en/3.2/pages/changelog.html?highlight=gl2_accounted_message_size#id7
Thanks, I’ll upgrade and test this !
I did the update … but the new dashboard takes getting used to it.
Where can I find this new function or do I have to do some further steps?
Create widget with aggregation function on field gl2_accounted_message_size. Field gl2_accounted_message_size you can found in left menu icon X1 (Fields) after click all including reserved and type gl2 on search field.
Found it thanks! But I can’t see an information in which pack of data they displayed? KB?
I think it’s bytes.
