Memory consumption above configuration limit
Hello
My machine is going out of memory after a few hours, graylog-datanode service is consuming more than the max memory assigned in configuration
  • OS Information: Redhat 9.6 , VM 20vcpu , 128Go RAM
  • Package Version: Graylog 6.3.3
  • around 400G logs per day
/etc/graylog/datanode/datanode.conf
node_id_file = /etc/graylog/datanode/node-id
config_location = /etc/graylog/datanode
bind_address = 0.0.0.0
opensearch_location = /usr/share/graylog-datanode/dist
opensearch_config_location = /var/lib/graylog-datanode/opensearch/config
opensearch_data_location = /logdata/opensearch/data
opensearch_logs_location = /data/log/graylog-datanode/opensearch
opensearch_heap = 62g
/etc/graylog/server/server.conf
is_leader = true
http_bind_address = 192.168.50.106:9000
http_enable_tls = false
disabled_retention_strategies = none,close
allow_highlighting = false
field_value_suggestion_mode = on
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 10
outputbuffer_processors = 10
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
message_journal_dir = /data/graylog-server/journal
message_journal_max_age = 72h
message_journal_max_size = 60gb
/etc/sysconfig/graylog-server
GRAYLOG_SERVER_JAVA_OPTS=“-Xms48g -Xmx48g -server -XX:+UseG1GC -XX:-OmitStackTraceInFastThrow”
GRAYLOG_SERVER_JAVA_OPTS=“$GRAYLOG_SERVER_JAVA_OPTS -Djdk.tls.acknowledgeCloseNotify=true -Djavax.net.ssl.trustStore=/etc/graylog/graylog.jks”
GRAYLOG_SERVER_JAVA_OPTS=“$GRAYLOG_SERVER_JAVA_OPTS -Dlog4j2.formatMsgNoLookups=true”
GRAYLOG_SERVER_ARGS=“”
GRAYLOG_COMMAND_WRAPPER=“”
/etc/graylog/datanode/jvm.options
-Xms48g
-Xmx48g
-XX:+UseG1GC
-XX:+UnlockExperimentalVMOptions
I have tried increasing or decreasing -Xmsg values and also the different buffers but with this configuration i have 82G memory for graylog-datanode.service
What am i missing or doing wrong here?
-Xmx is for JVM heap size but JVM consumes more memory than heap size : Google Search
This should be max half of present memory and is advised not to go beyond 32GB.
So you should have X nodes with 64GB and java memory configured at 32GB.
Does not mean the other 32GB is not used.
