Match a String Against Regex in Pipeline Processors
rule "TargetWorkstation"
to_string($message.TargetUserName)regex("(.*)\$", TargetUserName)
rename_field("TargetUserName", "TargetWorkstationName");
Hi guys, above you can see my attempt at matching a string with regex in a pipeline processor.
My aim is when the field TargetUserName ends with a dollar sign I would like the change the field name to TargetWorkstationName, I am just not sure how to match the field against the regex.
Regards,
George
You can access the boolean matches property of the result:
