logstash 6.8.9
nxlog conf
define ROOT D:\Program Files (x86)\nxlog
define CERTDIR %ROOT%\cert
define CONFDIR %ROOT%\conf
define LOGDIR %ROOT%\data
define LOGFILE %LOGDIR%\nxlog.log
LogFile %LOGFILE%
Moduledir %ROOT%\modules
CacheDir %ROOT%\data
Pidfile %ROOT%\data\nxlog.pid
SpoolDir %ROOT%\data
<Extension _gelf>
Module xm_gelf
</Extension>
<Extension _charconv>
Module xm_charconv
AutodetectCharsets iso8859-2, utf-8, utf-16, utf-32
</Extension>
<Extension _exec>
Module xm_exec
</Extension>
<Extension _fileop>
Module xm_fileop
# Check the size of our log file hourly, rotate if larger than 5MB
<Schedule>
Every 1 hour
Exec if (file_exists('%LOGFILE%') and \
(file_size('%LOGFILE%') >= 5M)) \
file_cycle('%LOGFILE%', 8);
</Schedule>
# Rotate our log file every week on Sunday at midnight
<Schedule>
When @weekly
Exec if file_exists('%LOGFILE%') file_cycle('%LOGFILE%', 8);
</Schedule>
</Extension>
<Input in>
Module im_msvistalog
</Input>
<Output out>
Module om_udp
Host 172.16.1.170
Port 6666
OutputType GELF
</Output>
<Route 1>
Path in => out
</Route>
logstash config
input {
gelf {
host => "0.0.0.0"
port_udp => 6666
use_udp => true
output {
kafka {
bootstrap_servers => "127.0.0.1:9092"
topic_id => "test"
max_request_size => 9044723
log from logstash raise a error, LogStash::Json::ParserError: Invalid UTF-8 middle byte 0x22
[2020-06-08T18:05:33,000][ERROR][logstash.inputs.gelf ] JSON parse failure. Falling back to plain-text {:error=>#<LogStash::Json::ParserError: Invalid UTF-8 middle byte 0x22
at [Source: (byte)“{“version”:“1.1”,”_Keywords":-9187343239835811840,“_EventType”:“ERROR”,“_SeverityValue”:4,“_Severity”:“ERROR”,“_EventID”:7000,“_SourceName”:“Service Control Manager”,“_ProviderGuid”:“{555908D1-A6D7-4695-8E1E-26931D2012F4}”,“_Version”:0,“_Task”:0,“_OpcodeValue”:0,“_RecordNumber”:234289,“_ProcessID”:820,“_ThreadID”:2872,“_Channel”:“System”,“_param1”:“THlpDrv”,“_param2”:“%%2”,“_EventReceivedTime”:“2020-06-08 18:05:17”,“_SourceModuleName”:“in”,“_SourceModuleType”:“im_msvistalog”,“host”:“DESKTOP-3N7O”[truncated 235 bytes]; line: 1, column: 598]>, :data=>“"{\"version\":\"1.1\",\"_Keywords\":-9187343239835811840,\"_EventType\":\"ERROR\",\"_SeverityValue\":4,\"_Severity\":\"ERROR\",\"_EventID\":7000,\"_SourceName\":\"Service Control Manager\",\"_ProviderGuid\":\"{555908D1-A6D7-4695-8E1E-26931D2012F4}\",\"_Version\":0,\"_Task\":0,\"_OpcodeValue\":0,\"_RecordNumber\":234289,\"_ProcessID\":820,\"_ThreadID\":2872,\"_Channel\":\"System\",\"_param1\":\"THlpDrv\",\"_param2\":\"%%2\",\"_EventReceivedTime\":\"2020-06-08 18:05:17\",\"_SourceModuleName\":\"in\",\"_SourceModuleType\":\"im_msvistalog\",\"host\":\"DESKTOP-3N7O189.com\",\"short_message\":\"\xE7\x94\xB1\xE4\xBA\x8E\xE4\xB8\x8B\xE5\x88\x97\xE9\x94\x99\xE8\xAF\xAF\xEF\xBC\x8CTHlpDrv \xE6\x9C\x8D\xE5\x8A\xA1\xE5\x90\xAF\xE5\x8A\xA8\xE5\xA4\xB1\xE8\xB4\xA5: \\r\\n\xE7\xB3\xBB\xE7\xBB\x9F\xE6\x89\xBE\xE4\xB8\x8D\xE5\",\"full_message\":\"\xE7\x94\xB1\xE4\xBA\x8E\xE4\xB8\x8B\xE5\x88\x97\xE9\x94\x99\xE8\xAF\xAF\xEF\xBC\x8CTHlpDrv \xE6\x9C\x8D\xE5\x8A\xA1\xE5\x90\xAF\xE5\x8A\xA8\xE5\xA4\xB1\xE8\xB4\xA5: \\r\\n\xE7\xB3\xBB\xE7\xBB\x9F\xE6\x89\xBE\xE4\xB8\x8D\xE5\x88\xB0\xE6\x8C\x87\xE5\xAE\x9A\xE7\x9A\x84\xE6\x96\x87\xE4\xBB\xB6\xE3\x80\x82\",\"timestamp\":1591610716,\"level\":3}"”}
where the config is wrong?
