I use Graylog3,elasticsearch 5.6,filebeat 5.6
i installed filebeat on our production log server ,we receive 2+GB/hour logs,after starting filebeat on the remote log server ,graylog application raise below alert :
Journal utilization is too high
Uncommited messages deleted from journal
and below logs entry in server.log
2019-07-09T11:10:41.576+02:00 WARN [KafkaJournal] Journal utilization (105.0%) has gone over 95%.
2019-07-09T11:10:43.319+02:00 INFO [KafkaJournal] Read offset 101601551 before start of log at 102050333, starting to read from the beginning of the journal.
2019-07-09T11:11:41.817+02:00 WARN [KafkaJournal] Journal utilization (103.0%) has gone over 95%.
2019-07-09T11:11:41.822+02:00 INFO [KafkaJournal] Read offset 102174535 before start of log at 102234700, starting to read from the beginning of the journal.
2019-07-09T11:12:41.613+02:00 WARN [KafkaJournal] Journal utilization (106.0%) has gone over 95%.
2019-07-09T11:12:41.721+02:00 INFO [KafkaJournal] Read offset 102375909 before start of log at 102785574, starting to read from the beginning of the journal.
2019-07-09T11:13:42.357+02:00 WARN [KafkaJournal] Journal utilization (108.0%) has gone over 95%.
2019-07-09T11:13:42.471+02:00 INFO [KafkaJournal] Read offset 102884614 before start of log at 103524467, starting to read from the beginning of the journal.
2019-07-09T11:14:42.538+02:00 WARN [KafkaJournal] Journal utilization (107.0%) has gone over 95%.
2019-07-09T11:14:44.976+02:00 INFO [KafkaJournal] Read offset 103639458 before start of log at 104256029, starting to read from the beginning of the journal.
2019-07-09T11:15:42.855+02:00 WARN [KafkaJournal] Journal utilization (107.0%) has gone over 95%.
2019-07-09T11:15:42.920+02:00 INFO [KafkaJournal] Read offset 104377272 before start of log at 104803020, starting to read from the beginning of the journal.
2019-07-09T11:16:41.813+02:00 WARN [KafkaJournal] Journal utilization (108.0%) has gone over 95%.
2019-07-09T11:16:41.894+02:00 INFO [KafkaJournal] Read offset 104919008 before start of log at 105533762, starting to read from the beginning of the journal.
2019-07-09T11:17:41.732+02:00 WARN [KafkaJournal] Journal utilization (107.0%) has gone over 95%.
2019-07-09T11:17:41.829+02:00 INFO [KafkaJournal] Read offset 105656889 before start of log at 106081359, starting to read from the beginning of the journal.
2019-07-09T11:18:42.539+02:00 WARN [KafkaJournal] Journal utilization (109.0%) has gone over 95%.
2019-07-09T11:18:42.596+02:00 INFO [KafkaJournal] Read offset 106177361 before start of log at 106814963, starting to read from the beginning of the journal.
2019-07-09T11:19:41.580+02:00 WARN [KafkaJournal] Journal utilization (108.0%) has gone over 95%.
2019-07-09T11:19:43.146+02:00 INFO [KafkaJournal] Read offset 106929802 before start of log at 107551218, starting to read from the beginning of the journal.
2019-07-09T11:20:41.599+02:00 WARN [KafkaJournal] Journal utilization (107.0%) has gone over 95%.
2019-07-09T11:20:41.649+02:00 INFO [KafkaJournal] Read offset 107661668 before start of log at 108273302, starting to read from the beginning of the journal.
2019-07-09T11:21:41.660+02:00 WARN [KafkaJournal] Journal utilization (108.0%) has gone over 95%.
2019-07-09T11:21:41.721+02:00 INFO [KafkaJournal] Read offset 108366905 before start of log at 109005791, starting to read from the beginning of the journal.
2019-07-09T11:22:41.686+02:00 WARN [KafkaJournal] Journal utilization (107.0%) has gone over 95%.
2019-07-09T11:22:41.756+02:00 INFO [KafkaJournal] Read offset 109119321 before start of log at 109552105, starting to read from the beginning of the journal.
after I saw these messages ,i tried to add another node to elasticserach cluster ,but the error still exist ,also logs appeared in graylog search but delayed
