Loadbalancer problen
Hi, i have 2 servers under LB.
i check ALIVE message by get http://:9000/api/system/lbstatus for server status
In two last weeks a get every half hour notification that one of servers not alive from LoadBalancer, all the time the same server.
When i cheek manually it’s always OK and LB alarms usually cleared in few seconds.
I think I lost connectivity or Graylog indication “ALIVE” for LB problem .
How i can check from GL if i have internal problem ? LOG?
check the logfile of that server. Check the metrics of that Server. You might be in some kind of overload problems.
what is metrics of that Server?
when i look on system/nodes page sometimes number of nodes disappears for few seconds and immediately returned ,this is a same problem ?
it might be.
By Metrics I mean, System Metrics collected and stored in a Metric storage to use something like Grafana or DataDog to get visuals of your server usage.
