We are using a Graylog cluster with Kubernetes with a loadbalancer for inputs.
The problem is the field “source” contain the IP of loadbalancer instead of server source IP.
Is there a a way to fix it ?
Regards
Regards
Hey,
I had a similar issue once upon a time and it was an LB setting that needed to be changed, I used nginx so it was proxy_bind $remote_addr transparent: https://stackoverflow.com/questions/42014538/nginx-load-balancer-not-passing-original-ip-address
Check up on the documentation for the load balancer you are using.
