LDAP authentication fine configuration question
Hi guys,
I have been using LDAP integrated authentication for some time, with group mapping and the setup works like a charm. The roles are mapped nicely and I am happy.
However I would like to prohibit most users from authenticating into Graylog at all. In other words I don’t want most LDAP users to be able to login to the GUI period.
How can that be accomplished? At present the “mortals” only get a minimal default role but they can still login to the GUI? How can I use group membership to completely block an LDAP login, not just use group membership for mapping onto roles?
Any advice would be appreciated!
Thank you
Hey @bubba198,
you can use a memberof restriction inside your User Search Pattern :slight_smile:
Here is one example, that we are using:
(&(objectClass=user)(sAMAccountName={0})(memberof=cn=LDAPGroupName,ou=Groups,ou=Ressourcen,dc=region,dc=company,dc=example,dc=de))
As a breakdown:
  • (& … ) – Chains all containing bracket groups like (objectClass=user) and (sAMAccountName={0})
  • (memberof=cn=LDAPGroupName,ou=… – Memberof condition that the userObject has to fullfill. Adapt your ou and dc parameters accordingly to your structure. :slight_smile:
Greetings - Phil
@derPhlipsi that’s excellent idea. Thank you! Testing now…
