It’s possible connect from graylog to kafka with ssl transport?
So, i have an answer on my own question.
Yes, it’s real.
Step by step:
- Clone the repo:
https://github.com/arsiesys/graylog-kafka-plugin - Install maven:
sudo yum install -y maven(if you use a centos) - Go to repo directory:
cd graylog-kafka-plugin - Launch build:
mvn package - Copy .jar file to your graylog plugin directory:
mv target/graylog-plugin-kafkanew-1.1.0.jar /usr/share/graylog/plugin/
After this, in Graylog System - Input you can select next:
- GELF Kafka New;
- Raw/Plaintext Kafka New;
- Syslog Kafka New;
And configure one of this input to connect your kafka to graylog with ssl.
he @MalinkinSA
you could have downloaded the release and no need to build it on your own:
but thanks for that.
Hi @jan
Many thanks for you answer, i did not notice availability ready build.
But i have a little feedback for all who want use it:
Unlike the built-in graylog kafka connector in this plugin lack of support custom Consumer name. I fixed it for my installation and send a pull request to added it.
