We receive Syslog messages from OPNsense, including IPS logs. The message is in JSON format. As mentioned in How to use a JSON Extractor, I created an extractor (to copy the message part into an named field and a separator to split the named field.
The extractor works. The messages are like this:
firewall.base.lan suricata[51566]: {"timestamp":"2023-06-14T21:14:06.502140+0200","flow_id":1143475206488403,"in_iface":"vlan01^","event_type":"alert","signature_id":2029022}
They new named field (suricata_json) look like this:
The JSON separator has the condition that signature_id exists. If I try the extractor, it works also:
However, the fields are not created. I yield the normal messages with the suricata_json extract, but the JSON part is not separated any further as intended with the second extractor. I have no further ideas. Are these two consecutive extractors the right approach?
OS Information: Ubuntu 22.04.2 LTS
Package Version: 5.0.8-1
Service logs, configurations, and environment variables: unknown
Adjust extractor conditions, watch the official video, searched for similar problems.
Assess the two extractor approach for the JSON data and/or give recommendation to extract JSON data into fields from the message part.
suggested tags: JSON, OPNsense, Suricata
