i installed graylog docker version on ubuntu, and trying to get Windows Events with Winlogbeat . Ubuntu host has 8 GB Ram 4 Core Cpu 256 GB disk, this is what it is look like;
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=22.04
DISTRIB_CODENAME=jammy
DISTRIB_DESCRIPTION="Ubuntu 22.04.5 LTS"
This is graylog conf file
is_master = true
node_id_file = /usr/share/graylog/data/config/node-id
root_username = admin
root_timezone = UTC
bin_dir = /usr/share/graylog/bin
data_dir = /usr/share/graylog/data
plugin_dir = /usr/share/graylog/plugin
elasticsearch_version_probe_attempts = 5
elasticsearch_version_probe_delay = 5s
elasticsearch_connect_timeout = 10s
elasticsearch_socket_timeout = 60s
rotation_strategy = count
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
allow_highlighting = false
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
message_journal_dir = data/journal
mongodb_uri = mongodb://mongodb/graylog
enabled_tls_protocols= TLSv1.2,TLSv1.3
prometheus_exporter_enabled = true
prometheus_exporter_bind_address = 127.0.0.1:9833
transport_email_hostname = outbound.mailhop.org
transport_email_port = 587
transport_email_use_auth = true
transport_email_use_tls = true
transport_email_auth_username = xxxxx
transport_email_auth_password = xxxxxx
transport_email_from_email = graylog@example.com
transport_email_web_interface_url = https://graylog.example.com
Winlogbeat conf file (installed with Graylog sidecar)
# Needed for Graylog
fields_under_root: true
fields.collector_node_id: DESKTOP-LOGPROVIDER
fields.gl2_source_collector: 9591####-####-####-####-fd7#####da54
output.logstash:
hosts: ["192.168.5.50:1514"] (fake ip, not real)
path:
data: C:\Program Files\Graylog\sidecar\generated\68665db149a37237d72eaf7e\data
logs: C:\Program Files\Graylog\sidecar\generated\68665db149a37237d72eaf7e\logs
tags:
- windows
winlogbeat:
event_logs:
- name: Application
ignore_older: 96h
- name: System
ignore_older: 96h
- name: Security
ignore_older: 96h
- name: Setup
ignore_older: 96h
- name: ForwardedEvents
forwarded: true
ignore_older: 96h
- name: Microsoft-Windows-Windows Defender/Operational
ignore_older: 96h
- name: Microsoft-Windows-Sysmon/Operational
ignore_older: 96h
- name: Microsoft-Windows-TerminalServices-LocalSessionManager/Operational
ignore_older: 96h
- name: Microsoft-Windows-PowerShell/Operational
ignore_older: 96h
- name: windows PowerShell
ignore_older: 96h
This is the Error i Receive;
Journal utilization is too high
(triggered 3 minutes ago)
Journal utilization is too high and may go over the limit soon. Please verify that your Elasticsearch cluster is healthy and fast enough. You may also want to review your Graylog journal settings and set a higher limit. (Node: 0eef#########################e54fe)
Uncommited messages deleted from journal
(triggered a few seconds ago)
Some messages were deleted from the Graylog journal before they could be written to Elasticsearch. Please verify that your Elasticsearch cluster is healthy and fast enough. You may also want to review your Graylog journal settings and set a higher limit. (Node: 0eef#########################17e54fe)
I tried to read old topics but i didn’t understand what to do, because suggestions are not for docker, and i dont have Elasticsearch confs.
Can you help me please.
Thanks.
