Issue with world map display
HI all,
I have the worldmap displaying the map as well as the data points. The problem is that it doesn’t display the city or country names. When you click on a datapoint, the popup just displays:
Name
No metric defined
Coordinates:
55.7386,37.6068
any thoughts on how to display city/country names?
many thanks.
Hello
I think that has to do with The GeoIP2 City database, but I’m not 100% sure.
https://www.maxmind.com/en/geoip2-services-and-databases
I was messing around with it, and came across the Metrics on the left. Have you tried that?
Hope that helps
Thanks, I tried card(src_ip_city_name) and popup just shows:
Name
Coordinates:
55.7386,37.6068
Value:
1
Can’t see how to get it to insert the actual name.
As stupid as it sounds I do not think you can do that. Would you mind opening a feature request for that?
If I am wrong one of my colleagues will close it with how to do it correctly.
- Konrad
