Hello Folks,
I am getting an issue with Elastic Search when I go to System Events stream.
I can’t see any errors in ES Logs.
Can anyone please guide me here?
Hello Folks,
Can you clarify what you are trying to do or what your expected outcome is? What page are you loading in the screenshot?
What version of graylog and Elasticsearch/OpenSearch are you running?
Also other than this, do you see messages in graylog?
Thank you for your response
I get this error when I select All System Events from Stream.
I also have other streams, but I don’t see this error in any.
I am using
Graylog Version: Graylog 4.3.14
Elasticsearch Version: 7.16.3
I don’t see errors in Elasticsearch. But I can see another error in graylog container.
But I assume this is something different. Or am I wrong? We are also trying to fix this.
I suspect this is expected behavior and indicates that there are no messages in that index. I believe newer versions of graylog (I know that 5.1 does) resolve that error where it just shows “no results” instead of that error.
I’m curious if you go to the Graylog System Events
index set via System / Indices, how many documents it shows in the index set. I’m guessing it is 0.
You are right. It shows 0 documents.
Thank you for your help
