Single Graylog node running 3.2.4 with free enterprise license
This event is logged every 5 minutes for past 5 days:
2020-04-23T15:50:03.362Z WARN [LicenseChecker] License violation - Detected irregular traffic records
What are traffic records in this context?
I have read quite a few threads on this but not come to much of a conclusion.
Server can reach the API:
# curl -v https://api.graylog.com
* Rebuilt URL to: https://api.graylog.com/
* Trying 52.2.164.113...
* TCP_NODELAY set
* Connected to api.graylog.com (52.2.164.113) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* successfully set certificate verify locations:
* CAfile: /etc/ssl/certs/ca-certificates.crt
CApath: /etc/ssl/certs
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
* TLSv1.3 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS handshake, Certificate (11):
* TLSv1.2 (IN), TLS handshake, Server key exchange (12):
* TLSv1.2 (IN), TLS handshake, Server finished (14):
* TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
* TLSv1.2 (OUT), TLS change cipher, Client hello (1):
* TLSv1.2 (OUT), TLS handshake, Finished (20):
* TLSv1.2 (IN), TLS handshake, Finished (20):
* SSL connection using TLSv1.2 / ECDHE-RSA-AES128-GCM-SHA256
* ALPN, server accepted to use http/1.1
* Server certificate:
* subject: CN=api.graylog.com
* start date: Apr 16 00:06:52 2020 GMT
* expire date: Jul 15 00:06:52 2020 GMT
* subjectAltName: host "api.graylog.com" matched cert's "api.graylog.com"
* issuer: C=US; O=Let's Encrypt; CN=Let's Encrypt Authority X3
* SSL certificate verify ok.
> GET / HTTP/1.1
> Host: api.graylog.com
> User-Agent: curl/7.58.0
> Accept: */*
< HTTP/1.1 200 OK
< Server: Cowboy
< Connection: keep-alive
< Date: Thu, 23 Apr 2020 15:58:28 GMT
< Content-Type: text/plain
< Vary: Accept-Encoding
< Content-Length: 133
< Via: 1.1 vegur
* Connection #0 to host api.graylog.com left intact
I have tested this multiple times, it always succeeds, Trying IP varies.
No messages in web interface about license violation.
Not getting anywhere near 5GB/day and never have done:
Looks like refreshing the /system/licenses page causes that event to be logged.
2020-04-23T15:40:03.346Z WARN [LicenseChecker] License violation - Detected irregular traffic records
2020-04-23T15:45:03.347Z WARN [LicenseChecker] License violation - Detected irregular traffic records
2020-04-23T15:55:03.346Z WARN [LicenseChecker] License violation - Detected irregular traffic records
2020-04-23T16:00:03.348Z WARN [LicenseChecker] License violation - Detected irregular traffic records
2020-04-23T16:05:03.349Z WARN [LicenseChecker] License violation - Detected irregular traffic records
2020-04-23T16:05:07.848Z WARN [LicenseChecker] License violation - Detected irregular traffic records
2020-04-23T16:10:03.386Z WARN [LicenseChecker] License violation - Detected irregular traffic records
2020-04-23T16:10:48.442Z WARN [LicenseChecker] License violation - Detected irregular traffic records
2020-04-23T16:11:23.836Z WARN [LicenseChecker] License violation - Detected irregular traffic records
lcosta
(Luis Miguel Costa)
April 24, 2020, 9:22pm
4
Hi there, thats wierd, do you have only one node? Is there a change that you have 2 ips in the same node? Duplicating traffic? Maybe use “netstat” to check the connections?
arrmo
(Russell Morris)
April 25, 2020, 8:54pm
5
Seeing exactly the same thing here - very odd. And only one node. Multiple IP’s, but that’s normal - IP for the NIC, but also, for example, there is an IP for the (cable) tuner card in the machine. Different network / subnet completely.
Thoughts?
Thanks!
One node with one IP, deployed using Graylog OVA. One data source sending syslog to Graylog. Basically, just about the most trivial use-case for Graylog I can imagine.
Would the “duplicating traffic” you’re referring to be duplicated logging records from things sending logs to Graylog? I can’t see this being the case here, it’s such a simple setup.
lcosta
(Luis Miguel Costa)
April 27, 2020, 11:48am
7
With the wirdness of the this, duplicating i mean if is receive 2 messages twice (for example) but if only use one “ip add” i don´t think thats the case.
arrmo
(Russell Morris)
April 27, 2020, 4:23pm
8
I checked my records, not seeing any duplicates … but of course I may be missing it. Any suggestions of a good way to check?
FYI, I did check - netstat result below (but not sure what it should be ). I’m listening on port 5140, avoid the < 1024 (root) issue.
netstat -ul | grep 5140
udp 0 0 0.0.0.0:5140 0.0.0.0:*
Thanks!
lcosta
(Luis Miguel Costa)
April 27, 2020, 4:42pm
9
well, i say, if you can do the things with the enterprise licence, you must ignore that warning. Maybe the measures for the message counting / traffic have a bug?
arrmo
(Russell Morris)
April 27, 2020, 7:51pm
10
Sure seems like it - thanks!
jan
(Jan Doberstein)
May 6, 2020, 2:17pm
11
please ignore this message.
While the wording is harsh it is nothing to worry about.
arrmo
(Russell Morris)
May 6, 2020, 3:37pm
12
Great, thanks - appreciate the note! Perhaps something to address in the SW longer term, but definitley not a priority of course.
