I have a single pipeline with the following extractor:
Trying to extract data from records_properties into , leaving the original intact.
I’m trying to write a write a pipeline rule that will drop messages where properties_smbCommandMajor == 9. properties_smbCommandMajor is a derived field from the extractor. I can search for properties_smbCommandMajor:9 and see results, but I cannot figure out the right syntax for the rule. Here’s what I think should work, but is not:
rule "drop if properties_smbCommandMajor == 9"
$message.properties_smbCommandMinor == 9
drop_message();
OS Information:
Private Build 17.0.3 on Linux 5.15.0-1014-azure
Package Version:
Graylog 4.3.3+86369d3
I’ve tried as many variations of $message.properties_smbCommandMinor == 9 that I can think of.
Please help me write the rule to drop messages where properties_smbCommandMajor == 9.
I wonder if it is a type issue where the data for properties_smbCommandMinor is stored as keyword… if so you could try putting quotes around the number…
Thank you for the quick reply. I tried $message.properties_smbCommandMinor == "9" as well as to_string($message.properties_smbCommandMinor) == "9". I also tried without $message like "properties_smbCommandMinor" == "9" and "properties_smbCommandMinor" == 9
Check your message processor configuration, you may want “Message Filter Chain” before “Pipeline Processor”
you can find out what is happening in a pipeline rule by using the debug() function… so something like this:
rule "check properties_smbCommandMajor"
has_field("properties_smbCommandMinor")
// use $ tail -f /var/log/graylog-server/server.log to watch for the results of the below debug message
debug(concat("============ properties_smbCommandMinor: ",to_string($message.properties_smbCommandMinor)));
Thank you again for your help. I tried your suggestion, but the condition has_field("properties_smbCommandMinor") didn’t result in anything being appended to the log. When I used the following code:
The following is appended to the log: WARN [EqualityExpression] left expression evaluated to null, returning false: $message.properties_smbCommandMinor
Does this mean the field $message.properties_smbCommandMinor does not exist? Could it be that pipelines rules are evaluated before extractors, in which case the field doesn’t exist yet?
I’ve attached a screenshot of the extractor configuration and you can see "smbCommandMajor":5 in the example message.
