Indexes and streams
i have default index set and two streams writing to this index set. as an admin i can use the search option and see all the messages from both streams.
today i added a new index set and a new stream writing only to the new stream.
now when i use the search option i cannot see all the messages from the older streams.
only if i enter the stream itself.
please explain why and how can i fix it
thanks
Please post the complete configuration of the index set and the stream you’ve created.
default index set:
Index shards 4
replicas 1
Max. number of segments 1
index rotation message count 20000000 do nothing
second index set
Index shards 4
replicas 1
index rotation by size 50G delete index
if you need more info please tell me how to extract it
thaks
streams:
All messages index set Default index set
logs index set Default index set
logs1 index set new index set
problem solved
the secret is to recalculate index range.
