Indexer Failures after upgrade to 2.3.1
I upgraded graylog to 2.3.1 and elasticsearch from 2 to 5.2.
According to the graylog console it can connect fine esearch after the upgrade, but now when I attempt to send syslog data I get the following index errors:
{"type":"mapper_parsing_exception","reason":"failed to parse","caused_by":{"type":"illegal_argument_exception","reason":"Can't parse [index] value [not_analyzed] for field [facility], expected [true] or [false]"}}
Did I forget to perform a post upgrade step?
I resolved the issue by rotating the index.
Can someone explain why it was necessary to rotate the index?
Because there were breaking changes in the index mapping between Elasticsearch 2.x and 5.x.
Please refer to https://www.elastic.co/guide/en/elasticsearch/reference/5.5/breaking-changes-5.0.html for details.
