Incoming Alarm Webvhook
Dear All,
Is it possible to create an incoming web hook using the API?
I have a service which can fire events to a web hook in AWS. I know, I could use AWS Lamdba to process web hook but want to pass it to Graylog?
Could the POST method in Stream/AlertConditions be used?
Kind Regards
Jake
He @Magneton
you would need to create a new input type for this - but you could add this to Graylog if you want. With Vanilla Graylog that is not easy, but with a little work, it is doable.
Hi Jan,
Would this need to be a plugin to create the new input type?
Cheers
Jake
yes - that would need to be a new input plugin.
