I Can not searching in graylog
I installed the Graylog as a multi setup node (3 node). I added one Syslog input correctly. but when I click on “show received messages”, I can not see any message, because it is in loading state as you see in the following photo
Hi Pouriajj,
Have you checked Graylog logs and/or Elasticsearch logs?
Also do try tcpdump to see if your Graylog server receives at all any logs.
Cheers.
  1. check your elastic cluster, it should have some error…
  2. check the quoted part. Graylog used these ports before version 2.5. I think you missed something at the installation.
  3. if you installed a 3 node cluster, why you use localhost addresses?
Hi macko003,
Yes, it’s strange. I didn’t configure it in graylog and elastic
I don’t know why used from 127.0.0.1:9350.
The elastic status is ok : (I didn’t see any error in elastic log)
[root@graylog2 ~]# curl -XGET ‘http://xx.xx.xx.84:9200/_cluster/health?pretty
“cluster_name” : “graylog”,
“status” : “green”,
“timed_out” : false,
“number_of_nodes” : 4,
“number_of_data_nodes” : 3,
“active_primary_shards” : 1,
“active_shards” : 1,
“relocating_shards” : 0,
“initializing_shards” : 0,
“unassigned_shards” : 0,
“delayed_unassigned_shards” : 0,
“number_of_pending_tasks” : 0,
“number_of_in_flight_fetch” : 0,
“task_max_waiting_in_queue_millis” : 0,
“active_shards_percent_as_number” : 100.0
Please check you installation again. In a 3 node cluster how do you have 4 nodes?
And also, check the graylog’s config and logs.
I Edited the graylog configuration :
elasticsearch_shards= 4 to 3
the node numbers have been changed to 6. It’s that strange :slight_smile:
[root@graylog1 ~]# curl -XGET ‘http://xx.xx.xx.84:9200/_cluster/health?pretty
“status” : “green”,
“number_of_nodes” : 6,
I removed “127.0.0.1” in the elastic and Graylog configs and The “127.0.0.1:9350” Error resolved in logs.
also in first host I have the warn log yet :
[searchResource] Unable to execute search : all shards failed
But didn’t have been change in search state in Graylog web GUI.
first fix your cluster.
In a 3 node cluster you should have 3 nodes. Surprise…
What do you get for the _cat/nodes url?
The output of command:
[root@graylog1 ~]# curl -XGET http://xx.xx.xx.84:9200/_cat/nodes
xx.xx.xx.84 xx.xx.xx.84 22 48 0.00 c - graylog-6d1d05c9-22c3-4c4b-b773-30b4a5aac0fb
xx.xx.xx.85 xx.xx.xx.85 22 44 0.00 c - graylog-224daa12-f08e-47f3-b474-b15b9bda387f
xx.xx.xx.85 xx.xx.xx.85 4 44 0.00 d m elasticsearch2
xx.xx.xx.86 xx.xx.xx.86 12 45 0.03 c - graylog-72f76a2c-7a72-4f0b-a66e-22d926013afb
xx.xx.xx.84 xx.xx.xx.84 7 48 0.00 d m elasticsearch1
xx.xx.xx.86 xx.xx.xx.86 4 45 0.03 d * elasticsearch3
what graylog and elasticsearch version do you use?
Graylog-server version : 2.0.3
elasticsearch version : 2.4.6
ahh… it is normal in this case. But Why do you use a 2-4 years old versions?
Use fresh once.
I installed Vi yum in centos7.
Is it mean that there is a bug in these versions?
If your response is yes , how to I upgrade these?
It is a very-very old version, I don’t know your problem come from a bug, or not, but I think you have no clue to use an outdated version.
I suggest to do a clean install.
https://docs.graylog.org/en/3.2/pages/installation.html
Thank you macko03.
I will try to installing the new version.
Hi macko003,
I installed the new version of elastic and Graylog.
elasticsearch version : 6.8.8-1
graylog-server version : 2.5.2-1
The issue resolved as you see in the following photo :
Thanks alot.
only I have warn message on all hosts :
WARN [NodePingThread] Did not find meta info of this node. Re-registering.
Graylog 3.2 is the last one.
But there are a lot of information about disadvantages about the new style, so maybe the 3.1 is a good one too.
