HTTP JSON path data adapter - private HTTPS API certification problems
I’m having trouble using the HTTP JSON path data adapter from graylog due to HTTPS certification problems.
I’ve developed a small web service that responds to HTTPS requests with JSON values, the requests are of the the form:
curl -s -G --data-urlencode 'hash=415f12a879deceb0d90b8953154a1ad80ab7fc40' https://my-private-web-service.my.internal.domain | jq
  "updated": true,
  "hash": "415f12a879deceb0d90b8953154a1ad80ab7fc40",
  "value": {
    "description": "interesting stuff"
The certificate presented is a wildcard for *.my.internal.domain
Previously I’ve installed a private Windows Active Directory CA certificate in all my managed Linux systems, and as you can see this is working perfectly with curl.
1. Steps taken
keytool -keystore /etc/pki/ca-trust/extracted/java/cacerts -list | grep -A 1 -i mydomain
mydomain-ca, Sep 29, 2021, trustedCertEntry,
Certificate fingerprint (SHA1): SA:NI:TI:SE:DF:IN:GE:RP:RI:NT
  • added -Djavax.net.ssl.trustStore=/etc/pki/ca-trust/extracted/java/cacerts to GRAYLOG_SERVER_JAVA_OPTS in /etc/sysconfig/graylog
  • restarted the graylog-server, no errors are logged
2. My Environment:
  • CentOS 7
  • graylog 3.1
I get this in the logs when trying to manually lookup the same key as in the curl example:
2021-12-14T11:58:32.326Z ERROR [HTTPJSONPathDataAdapter] HTTP request error for key <415f12a879deceb0d90b8953154a1ad80ab7fc40>
javax.net.ssl.SSLPeerUnverifiedException: Hostname my-private-web-service.my.internal.domain not verified:
    certificate: sha256/manyrandomchars
    DN: EMAILADDRESS=some-email@my.company, CN=*.my.internal.domain, O=My Company, L=MyCity, ST=MyRegion, C=MyCountry
    subjectAltNames: []
however:
ps -ef | grep -w java | grep -w graylog
graylog    3715   3698  7 11:57 ?        00:05:35 /usr/bin/java -Xms1g -Xmx1g -XX:NewRatio=1 -server -XX:+ResizeTLAB -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -XX:-OmitStackTraceInFastThrow -Dlog4j2.formatMsgNoLookups=true -Djavax.net.ssl.trustStore=/etc/pki/ca-trust/extracted/java/cacerts -Djavax.net.ssl.trustStorePassword=changeit -XX:+UseParNewGC -jar -Dlog4j.configurationFile=file:///etc/graylog/server/log4j2.xml -Djava.library.path=/usr/share/graylog-server/lib/sigar -Dgraylog2.installation_source=rpm /usr/share/graylog-server/graylog.jar server -f /etc/graylog/server/server.conf -np
3. Troubleshooting
  • I looked into the documentation but found nothing regarding using the system’s trusted CA
  • Other similar data adapters work perfectly with public CA certificates, or plain HTTP
  • explain what I’m doing wrong
  • point in the right direction
Thanks in advance
Couple things to check.
Does graylog have access your keystore?
sudo chown graylog:graylog
Are certificate/s in the right format for Graylog and are the correct certificates installed in the keystore?
https://docs.graylog.org/v1/docs/https
https://docs.graylog.org/v1/docs/sec-adcs-certificates
EDIT: I would also check your /etc/hosts file (i.e. 8.8.8.8 graylog.domain.com) and if your running DNS server make sure the reverse lookup (PTR) is correct.
