How to use Regex
I don’t know how to use Regex to process log messages in JSON format. I would like to find some examples. Can I provide some trouble? thank you very much.
What are you trying to accomplish?
Please provide some examples.
I want to parse some JSON formatted logs. E.g:
{"url": "POST /PutData?Category=YunOsAccountOpLog&AccessKeyId=U0UjpekFQOVJW45A&Date=Fri%2C%2028%20Jun%202013%2006%3A53%3A30%20GMT&Topic=raw&Signature=pD12XYLmGxKQ%2Bmkd6x7hAgQ7b1c%3D HTTP/1.1", "ip": "10.200.98.220", "user-agent": "aliyun-sdk-java", "request": {"status": "200", "latency": "18204"}, "time": "05/May/2016:13:30:28"}
The following is the parsing method I use, but it’s always wrong:
Rule "json"
When
    True
Then
    Let json = parse_json(to_string($message.message));
  Set_fields(json);
End
What does that mean exactly?
What do you expect as a result and what is the actual result?
Expect to show in this way:
Ip
10.200.98.220
User-agent
Aliyun-sdk-java
Status
200
Latency
18204
And what is the actual result with your pipeline rule?
No processing log message.
Is the rule assigned to a processing pipeline?
Is the processing pipeline connected to a stream?
Does the rule work in the pipeline simulator?
Oh, it was my fault. I did not find change in the name of the rule. Thank you for your suggestion. It helps me very much.
