How to use existing Elasticsearch 5.3 for sending logs
Hello, I’m currently using Elasticsearch 5.3 and all applications are sent logs to Elasticsearch.
App -> LogStash -> ElasticSearch 5.3
How can I integrate Graylog 3.1 with existing Elasticsearch 5.3. What are the best practices to integrate Gralog with existing Logstash&Elasticsearch?
he @oiboran
Graylog can be used to replace logstash - but you can’t read the logs you already have in elasticsearch that are send in via logstash. As this is not a replacement for kibana, it is a different tool.
Jan
