I added a few most used fields to the stream ,but the preferred view need to apply everytime. is there any way to add certain fields to the default view?
or set a view as default?
Thanks.
You can’t change default field to show, but still you can Save your search and then Load anytime manually.
If you thinks it’s a feature request that will also help other people, please create feature request: Issues · Graylog2/graylog2-server · GitHub
