How to set a saved Search as default view
Is there a way to have Graylog open a saved search as your default start page when you login?
AFAIK not directly. You can make dashboard and set it as start page in user profile settings.
That works, thank you. What tripped me up was I was trying to do it as the Admin account which was read only. Thanks for your help
