How to send logs into graylog cluster
Hi
I wanted to use HAproxy in front of my graylog cluster (3 nodes Graylog and 3 nodes Elasticsearch) to load balancing the Web loggins and log sendings
The Web loadbalancing worked with HAproxy but I didn’t get the syslogs (udp) in my cluster. I read that udp isn’t supported. If I sent the logs directly to one graylog server it worked.
Is there a way to load balancing / sending the logs to my Graylog cluster especially to my two processing Servers?
Thanks!!
Nginx supports UDP
Thanks I have noticed that. In case I am not finding a solution with the HAproxy i will try it with the nginx.
