How to search logs with graylog
i use the graysquid Input in order to collect the squid’s logs, but when i want to search a log which contain the string of caracters “cucumber”, there a message in Search, fields : message : Analysis features for this field have been disabled by the administrator.
how to enable it ?
Thanks you by advance
  • What exactly is your search string?
  • What Elasticsearch Version did you have?
Re,
What exactly is your search string ?
It’s the domain-name of an website, exemple : www.google.fr
My Elasticsearch version :
elasticsearch-5.6.9-1.noarch
@flo so you just type in
www.google.fr
in the search field of Graylog?
Oh thanks a lot i found the research bouton ! :smiley:
Now i would like to search a keyword with regular expression like : google
Because your solution works only with complete domain-name: www.google.fr
(sorry for my bad english)
The “Filter Fields” text input only filters available message fields, e. g. you could enter “appl” and it would show the “application_name” field.
If you want to search field contents, you’ll have to use the search input on top (next to the green button with the white magnifying glass).
