How to resolve issue with indexer
I have following architecture Logstash -> RabbitMQ ->Graylog
I have issue in indexer with parsing:
17 minutes ago graylog_0 d58fe350-f41b-11e6-8407-000c29438b97 MapperParsingException[failed to parse [level]]; nested: NumberFormatException[For input string: "information"]
In logstash debug I can see message like this:
             "devid" => "FGVMEV0000000000",
       "raw_message" => "date=2017-02-16 time=00:55:46 devname=FortiGate-VM64 devid=FGVMEV0000000000 logid=0100040704 type=event subtype=system level=notice vd=root logdesc=\"System performance statistics\" action=\"perf-stats\" cpu=0 mem=47 totalsession=3 disk=0 bandwidth=0/0 setuprate=0 disklograte=0 fazlograte=0 msg=\"Performance statistics: average CPU: 0, memory:  47, concurrent sessions:  3, setup-rate: 0\"",
        "fazlograte" => "0",
              "type" => "fortigate",
               "mem" => "47",
    "syslog5424_pri" => "189",
          "@version" => "1",
              "host" => "10.0.0.90",
            "action" => "perf-stats",
       "disklograte" => "0",
         "device_id" => "FortiGate-VM64",
             "level" => "notice",
         "bandwidth" => "0/0",
               "cpu" => "0",
         "<189>date" => "2017-02-16",
           "message" => "<189>date=2017-02-16 time=00:55:46 devname=FortiGate-VM64 devid=FGVMEV0000000000 logid=0100040704 type=event subtype=system level=notice vd=root logdesc=\"System performance statistics\" action=\"perf-stats\" cpu=0 mem=47 totalsession=3 disk=0 bandwidth=0/0 setuprate=0 disklograte=0 fazlograte=0 msg=\"Performance statistics: average CPU: 0, memory:  47, concurrent sessions:  3, setup-rate: 0\"",
                "vd" => "root",
           "logdesc" => "System performance statistics",
              "disk" => "0",
        "@timestamp" => 2017-02-16T07:55:39.383Z,
         "setuprate" => "0",
             "logid" => "0100040704",
              "time" => "00:55:46",
      "totalsession" => "3"
Can you please help? I do not understand why level is not parsed it is string like others that are parsed correctly.
Thank you!
Jiri
Hi Jiří,
the level message field has to be a numeric value, i. e. the numeric severity level of syslog messages: https://en.wikipedia.org/wiki/Syslog#Severity_level
You can use message processor pipeline rules to change that in Graylog: http://docs.graylog.org/en/2.2/pages/pipelines.html
Although in your specific case, I’d recommend converting the “level” field in Logstash.
Cheers,
Jochen
