Hi folks,
Once elasticsearch_discovery_enabled
is true, is there any way to track what Elasticsearch nodes Graylog is communicating? Could be log messages, metrics, web UI, anything.
Thanks in advance.
Rodrigo
Hi folks,
Thanks in advance.
Rodrigo
I think you have about a million solution. Choose one, and use it.
search for message
check system overview
check indices
or metrics
Hi Macko003,
If I understood it correct, your suggestion would show more the “overall communication” between Graylog and Elasticsarch clusters.
I was hoping to have something more specific, that shows exactly what Elasticsearch nodes got discovered by Graylog.
I already have enough Prometheus metrics showing Graylog and Elasticsearch clusters health
Thank you,
Rodrigo
