Background
One of our devices is sending us a message in JSON, that contains another JSON object inside.
I know I can use the default JSON extractor for the first level:
http://docs.graylog.org/en/2.4/pages/extractors.html#using-the-json-extractor
But I am not sure of what I can do for the second.
Message
"imei":"35205",
"messages":[
"d":"{\"n\":\"352094089228305\",\"b\":0,\"l\":1527068689,\"v\":\"03.00\",\"t\":2}"
"d":"{\"n\":\"352094089228305\",\"b\":0,\"l\":1527069373,\"v\":\"03.00\",\"t\":1,\"d\":[[1527069373,0,0,0,0,1]]}"
"d":"{\"n\":\"352094089228305\",\"b\":0,\"l\":1527069387,\"v\":\"03.00\",\"t\":2}"
"d":"{\"n\":\"352094089228305\",\"b\":0,\"l\":1527069402,\"v\":\"03.00\",\"t\":2}"
"d":"{\"n\":\"352094089228305\",\"b\":0,\"l\":1527069417,\"v\":\"03.00\",\"t\":2}"
"d":"{\"n\":\"352094089228305\",\"b\":0,\"l\":1527069451,\"v\":\"03.00\",\"t\":1,\"d\":[[1527069451,0,0,0,0,1]]}"
As you can see, this JSON object has 2 properties:
- imei: the id of the device
- messages: an array of messages
Each message of this array is a JSON object itself, which I also want to extract, but don’t know how to.
Problem
If I apply a JSON extractor to full_message ( which is what I do ) then I get an object with an imei, which is good and a messages array that contains a set of huge strings … which I don’t want, I actually want the contents of those strings !
Question
How can I extract the message object inside the messages array?
