How to create input to receive wazuh-hids logs
Can any one help me create an input to receive wazuh-hids logs? I tried to create udp input on port 1514, it didn’t work.
we can help, but we’ll need more information. What did you do? Why do you say it didn’t work? Error messages, configs, etc… otherwise… 42 :slight_smile:
Thank you for responding, I figured it out. I believe the issue occurred because I created the input on the port 1514 which is used by wazuh manager, so i changed the input port and added a syslog output config in wazuh manager. Now it’s working.
