How to add multiple host and IP in stream rule
Hello Friends,
As I am getting requests from multiple host machines, how to create stream rule so that all messages can get on a single port.
Create more stream rules with condition any match (not all match).
I am not able to send my log message from fluentbit to Graylog. I am using gelf setting. I have used same settings for another clients those are working . But some clients are not working.
Check graylog server log file for any errors, maybe your gelf is not complaint.
sudo tail -f /var/log/graylog-server/server.log
Request is not reaching to Graylog. I can see in the logs for other clients IP, it’s showing but some it’s not.
I have compared both configuration no difference.
Maybe there is a firewall, that blocks such connection, please check…
If you use GELP HTTP input try to send example message using curl:
curl -XPOST http://graylog.example.org:12202/gelf -p0 -d '{"short_message":"Hello there", "host":"example.org", "facility":"test", "_foo":"bar"}'
If you use GELF UDP input try to send example message using nc:
echo -n '{ "version": "1.1", "host": "example.org", "short_message": "A short message", "level": 5, "_some_info": "foo" }' | nc -w0 -u graylog.example.com 12201
If you use GELP TCP input try to send example message using nc:
echo -n -e '{ "version": "1.1", "host": "example.org", "short_message": "A short message", "level": 5, "_some_info": "foo" }'"\0" | nc -w0 graylog.example.com 12201
Hi Shootub,
I have used below command as we are using GELF TCP.
echo -n -e '{ "version": "1.1", "host": "example.org", "short_message": "A short message", "level": 5, "_some_info": "foo" }'"\0" | nc -w0 10.24.11.23 12201
But we are getting below error.
Ncat: Invalid -w timeout (must be greater than 0). QUITTING.
Then i replaced | nc -w0 with | nc -w1 and executed below command.
echo -n -e ‘{ “version”: “1.1”, “host”: “example.org”, “short_message”: “A short message”, “level”: 5, “_some_info”: “foo” }’"\0" | nc -w1 10.24.11.23 12201
Above command not showing me any error but i can’t see any message in Graylog UI and logs.
Yes, you are right, w0 is parameter for older version of nc.
It should definitely work. If not, try to check if something not block this connection, like firewall. Try to telnet to port, to check if your connection in not blocked:
telnet 10.24.11.23 12201
If not works, try to create new test Gelf TCP input with different port, and try it.
