How do you prevent killing graylog Server from index failures?
Last week I had two index failures due to too long stack traces.
The Graylog server had stopped responding and I had to restart it.
The debugging of such index failures is a pain in the a… But that’s another point.
How do you prevent your environment from such faults ? I tried it with a custom mapping and ignore_above, but the message field is a text field (because of field anaylsis ) and ignore_above works only with a keyword.
you could check the size - or the number of bytes - in the field and reduce that/write that into another field then.
Or you check if this is a stacktrace and if that is true, write the content in a specific field as keyword and delete the content from the message field or replace it.
Hi Jan,
I have now deposited the following pipeline rule:
rule "abbreviate messages over 30000 characters"
    has_field("message") AND
    regex("^.{30000,}$", to_string($message.message)).matches == true
    set_field("message", abbreviate(to_string($message.message), 30000));
    debug( concat("abbreviate oversized message from ", to_string($message.source)));
And it seems to work :slight_smile:
Thanks.
