How can we improve output message rate to elasticsearch
Hi
From a few days, we are having more than 10 million backlog on 3 graylog nodes. Tried everything but didn’t find any solution. This is our daily problem now. Message in count is much more than out. Please help me with this.
In my environment, I am using 7 gl nodes, 3 es master nodes and 4 es data nodes.
Graylog Versio - 2.4
Elasticserach Version - 5.6
I have 7 Gl Nodes and each having the same configuration.
Hardware Configuration (for every nodes)
Architecture:          x86_64
CPU op-mode(s):        32-bit, 64-bit
Byte Order:            Little Endian
CPU(s):                16
              total        used        free      shared  buff/cache   available
Mem:            29G         23G        210M        1.4G        5.8G        4.1G
Swap:            0B
server.conf (for every nodes)
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 16
outputbuffer_processors = 3
# The following settings (outputbuffer_processor_*) configure the thread pools backing each output buffer processor.
# See https://docs.oracle.com/javase/8/docs/api/java/util/concurrent/ThreadPoolExecutor.html for technical details
# When the number of threads is greater than the core (see outputbuffer_processor_threads_core_pool_size),
# this is the maximum time in milliseconds that excess idle threads will wait for new tasks before terminating.
# Default: 5000
# The number of threads to keep in the pool, even if they are idle, unless allowCoreThreadTimeOut is set
# Default: 3
# The maximum number of threads to allow in the pool
# Default: 30
# Possible types:
#  - yielding
#  - sleeping
#  - blocking
#  - busy_spinning
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
# Enable the disk based message journal.
JVM Heap size
GRAYLOG_SERVER_JAVA_OPTS="-Xms15g -Xmx15g
es node hardware(for every nodes)
CPU(s):                8
es configs (for every nodes)
# ======================== Elasticsearch Configuration =========================
# NOTE: Elasticsearch comes with reasonable defaults for most settings.
#       Before you set out to tweak and tune the configuration, make sure you
#       understand what are you trying to accomplish and the consequences.
# The primary way of configuring a node is via this file. This template lists
# the most important settings you may want to configure for a production cluster.
# Please consult the documentation for further information on configuration options:
# https://www.elastic.co/guide/en/elasticsearch/reference/index.html
# ---------------------------------- Cluster -----------------------------------
# Use a descriptive name for your cluster:
cluster.name: graylog
# ------------------------------------ Node ------------------------------------
# Use a descriptive name for the node:
node.name: es-data01.mykaarma.com
# Add custom attributes to the node:
#node.attr.rack: r1
node.master: false
node.data: true
# ----------------------------------- Paths ------------------------------------
# Path to directory where to store the data (separate multiple locations by comma):
#path.data: /path/to/data
# Path to log files:
#path.logs: /path/to/logs
# ----------------------------------- Memory -----------------------------------
# Lock the memory on startup:
#bootstrap.memory_lock: true
# Make sure that the heap size is set to about half the memory available
# on the system and that the owner of the process is allowed to use this
# limit.
# Elasticsearch performs poorly when the system is swapping the memory.
# ---------------------------------- Network -----------------------------------
# Set the bind address to a specific IP (IPv4 or IPv6):
network.host: 0.0.0.0
# Set a custom port for HTTP:
#http.port: 9200
# For more information, consult the network module documentation.
# --------------------------------- Discovery ----------------------------------
# Pass an initial list of hosts to perform discovery when new node is started:
# The default list of hosts is ["127.0.0.1", "[::1]"]
discovery.zen.ping.unicast.hosts:["10.0.15.13", "10.0.15.132", "10.0.15.133", "10.0.15.134", "10.0.15.135", "10.0.15.136", "10.0.15.137"]
# Prevent the "split brain" by configuring the majority of nodes (total number of master-eligible nodes / 2 + 1):
discovery.zen.minimum_master_nodes: 2
# For more information, consult the zen discovery module documentation.
# ---------------------------------- Gateway -----------------------------------
# Block initial recovery after a full cluster restart until N nodes are started:
#gateway.recover_after_nodes: 3
# For more information, consult the gateway module documentation.
# ---------------------------------- Various -----------------------------------
# Require explicit names when deleting indices:
#action.destructive_requires_name: true
#bootstrap.mlockall: true
#indices.store.throttle.max_bytes_per_sec: 1024mb
JVM Heap size
-Xms28g
-Xmx28g
Please let me know if I missing any configuration.
A quick reply will be appreciated.
Thanks in advance.
my personal idea is more that Elasticsearch is not able to take all the messages you try to ingest to it!
you might also raise the output batch size that you have ~5000 messages per batch and not only 500 that should give you a little more room.
