I’m having trouble with a seemingly simple pipeline rule. I’m wondering if anyone could take a look at it and tell me if I’m missing something. Here’s the rule:
rule "rtl type OTHER"
NOT has_field("type")
set_field("type", "OTHER");
The intent of the rule is to set the field ‘type’ to the string “OTHER” if the field ‘type’ doesn’t exist. I have two other rules that are working fine that set the ‘type’ field based on the existence of other fields. This is the only one doing so based on NOT having a field.
I have 2 rules in “Stage 0” which both detect the presence of a field and set ‘type’ based on that criteria. Then in Stage 3, I have this rule as a catch all. However, while the first 2 rules are working, this last one never sets the type to “OTHER” as expected.
Any ideas of where I’m going wrong?
