Help Regex in Graylog
Hello, I am receiving the message:
container_name:crm-tickets, namespace_name:crm, pod_name:crm-tickets-6b87984578-jsgzf, container_image:[gcio.io/crm-teste:3](http://gcio.io/crm-teste:3)
i need to create a regex to fields
container_name: crm-tickets
namespace_name: crm
is possible ?
I Try:
^container_name?[:\s]\w+
thanks
Are you trying to create an extractor or a pipeline rule?
You might want to have a look here:
http://docs.graylog.org/en/3.0/pages/extractors.html
http://docs.graylog.org/en/3.0/pages/pipelines/functions.html#regex
You can build and test your Regex here:
https://www.freeformatter.com/java-regex-tester.html
