Help in Better performance of my Elasticsearch-Graylog Setup
Hi Team,
I have a setup of 3 Graylog Nodes and 5 ES nodes. The search queries in my setup take about 400ms- 500ms to execute. Can you help with speeding up the execution time?
The ES config file looks like:
curl -XPUT "https://graylog-es-cluster.service.%%RUNTIMEDC%%.coi:9200/_cluster/settings" -d '{
  "persistent" : {
    "indices.recovery.max_bytes_per_sec": "100mb",
    "cluster.routing.allocation.cluster_concurrent_rebalance": 10,
    "cluster.routing.allocation.node_concurrent_recoveries": 10
It’ll be a great help if anyone could give a solution to speed up the queries to a shorter time span?
Thanks,
Srijoni
For legibility, could you please go back and edit your post? Select the copy/pasted CURL-stuff and hit that </> button. This makes for much nicer formatting.
The amount of nodes you have is only one fraction of the whole puzzle :slight_smile:
  • How big is your whole data set?
  • How many indexes do you have?
  • What is your sharding/replication strategy in Elastic?
  • Are you querying against the full data set or one index?
There are so many factors that we need to know :slight_smile: If I’m querying a few TB of data for a complicated pattern with many ANDs and ORs, I’d be happy with 400-500ms :slight_smile:
  • How much memory and heap does the ES have?
  • How much is the heap usage?
  • Do you see any io wait on your ES servers?
  • Any cpu/load problem?
monitor,monitor, monitor all necessary parameters. After you do it, monitor all unnecessary parameter too! It can be helpful when you need to debug…
//I think the 4-500 ms query time not a big problem.
Then again, you are one of those folks I was referring to, with the humongous datasets :slight_smile:
You may want to add a few data nodes to your Elastic cluster :slight_smile:
I’ll have you know most of our queries complete in <200ms … super long time range ones still come in under 500ms so I’m with @macko003 there, 500ms isn’t bad :smiley:
Shards: 4
Replicas :1
Index rotation strategy: Index Size
Max Index size: 5.0GB
Querying against indexes
On 5 ES nodes, even searching across that entire index set should complete way faster, in a few dozen ms even. Looks like your ES nodes are either all on the same server, or hilariously underpowered. Got specs?
Graylog:
CPU: 5 cores
Memory: 10 GiB
ES:
CPU: 3 cores
Memory: 30 GiB
Anyother specs you looking for in particular?
Okay, so for ES, you want at least 64Gb of RAM with 32Gb allocated to ES, and at least 8 cores - anything below that will cause slow performance.
Okaaay! If with my current specs, I implement the following tuning, will they cause any significant changes?
Solutions:
  • refresh_interval to 30 seconds in ES
  • Graylog server.conf : increase output_batch_size outputbuffer_processors
  • Adding a node to Graylog.
Wanted to check if I could extend the current setup to the max performance.
None of this will make any difference to be honest, you need to tune Elasticsearch, not Graylog - so bigger CPU on Elastic, bigger memory as well. Otherwise everything else isn’t worth it :slight_smile:
