I have the following results where I am trying to get the iso_code and names[en] in a pipline rule.
because the result of subdivisions is a list or dictionaries, i have tried a few things and cannot get any results.
can anyone tell me what I’m doing wrong? thanks!
geo["subdivisions"][0].iso_code
geo["subdivisions"].0.iso_code
geo["subdivisions"].iso_code
"subdivisions": [
"confidence": null,
"geoname_id": 2951839,
"iso_code": "BY",
"names": {
"de": "Bayern",
"ru": "Бавария",
"pt-BR": "Baviera",
"ja": "バイエルン",
"en": "Bavaria",
"fr": "Bavière",
"zh-CN": "巴伐利亚州",
"es": "Baviera"
Well, on Github I found that I can try .[0]., ill keep you posted if it works.
.[0]. did Work, I found the post below from version 5.2 that haven’t been updated in over a year but it looks like its not fixed.
opened 07:36AM - 29 Apr 19 UTC
closed 08:04AM - 28 Jul 22 UTC
processing
bug
triaged
#M
I am trying to setup a pipeline rule to get some additional geo information, as … described in http://docs.graylog.org/en/3.0/pages/geolocation.html#.
The problem I am facing is that part of the result of the lookup can be empty.
In the below code for the rule setting the country code works fine, but the fields which depend on the subdivisions object can lead to the error
"For rule 'rule geoip lookup': In call to function 'set_field' at 7:2 an exception was thrown: Index: 0, Size: 0".
This happens because the subdivisions object is sometimes empty, for instance:
"country": {
"confidence": null,
"geoname_id": 1605651,
"is_in_european_union": false,
"iso_code": "TH",
"names": {
"de": "Thailand",
"ru": "Тайланд",
"pt-BR": "Tailândia",
"ja": "タイ王国",
"en": "Thailand",
"fr": "Thaïlande",
"zh-CN": "泰国",
"es": "Tailandia"
"subdivisions": []
Code for the rule:
rule "rule geoip subdivision lookup"
has_field("IP")
let geo = lookup("geoip-lookup", to_string($message.IP));
set_field("IP_country_code", geo["country"].iso_code);
set_field("IP_region_code", geo["subdivisions"].[0].iso_code);
set_field("IP_region_name", geo["subdivisions"].[0].names.en);
Currently it seems not to be possible to only set the fiels IP_region_code and IP_region_name, when the array is not empty - or to use a default value, if the array is empty.
(Also posted in https://community.graylog.org/t/pipeline-rule-with-geo-lookup-and-possible-empty-array/10013)
I also tried: set_field(“destination_ip_state_abbrev”, to_string(geo[“subdivisions”].[0].iso_code)); per the post and its still failing. Did anyone get that working? Thanks
This was the fix per github, works 50% of the time. Still issues when the list is empty as 0 shows up as invalid index. Works fine when its present.
set_field("destination_ip_state", to_string(geo["subdivisions"].[0].names.en, "", "", "", "no_value"));
